Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Ray i was asking for torque specs for a Briggs and Stratton flywheel bolt model 31P977 it is a 20 hp motor. how many foot pounds of torque do i tighten it to. i would use a torque wrench.
    Top Expert:
  • Briggs & Str... Master
  • 44,232 Answers
50 ft lbs should do it
Posted on Apr 20, 2015
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
Torque Peugeot 206
You will find all the torque specs for your car in the factory repair manual.
Dec 13, 2015 | Peugeot Cars & Trucks
Does anyone know the head torque specs and tightening sequence (if necessary) for B&S 42A707 Type 2238 E1 17 HP? Thanks.
briggs has service manuals available on their website... take those numbers and search... and yes. they have a sequence and a torque spec. which is 160 inch pounds
Oct 25, 2014 | Briggs & Stratton Garden
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Need timming specks & torgue speck for rod bolts
There are no timing "specs", if the flywheel key is good and the magneto air gap is properly set, the timing will be right.
Torque for the rod bolts is 45 INCH pounds - NOTE INCH pounds not foot pounds
Sep 23, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
Bolt torque specs for flywheel, pressure plate, bell housing bolts for 97 Nissan maxima
1.Flywheel - 61 to 69 Foot Pounds
2.Pressure Plate - 25 to 33 Foot Pounds
3.Bell Housing - No specs found. I would say 25 to 35 foot pounds should be sufficient.
Bolts clean on ->flywheel to crank, ->pressure plate to flywheel, and ->bell housing to back of engine, I would use TWO drops of Loctite Red threadlocker, on ALL of these bolts.
Hope you have an alignment tool for your clutch disk when you install it. Auto parts stores sell the plastic one's cheap! Saves a LOT of headaches!
Tighten the pressure plate EVENLY! Snug the bolts down until they just TOUCH, then go in a criss-cross pattern when tightening. Do the tightening in incremental stages! You turn one bolt one thread, you go across to the opposite side, and turn that bolt one thread. Keep criss-crossing so the pressure plate goes down EVENLY. (YES, it's a pain in the keister!)
If NOT, you'll have a warped pressure plate, and it will be junk!
Thanks for letting me say that, I feel better.
Jul 07, 2009 | 1997 Nissan Maxima
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
259 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
