Question about Ovens
Replace keyboard control - Ovens
    Top Expert:
  • Ovens Master
  • 47,720 Answers
Call a service repairman
Posted on Apr 20, 2015
I have a turbo chef tornado 2 (subway) ...my keypad doesn't always work. I had a repair company look at it and he said he thinks it's the control board. His reasoning is that the keypad works most of the...
lets start here before taking anything apart . contact the company and see if the parts they think are needed are still available. If so then you could price then and if you decide it worth that price proceed .
Jan 28, 2015 | Ovens
F2 shows on display on whirlpool gas stove
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
May 14, 2014 | Whirlpool RBS305PDS Electric Single Oven
Can't stop keypad beeping on every key
Go onto control panel and click on keyboard settings and or the mouse settings to adjust sounds.
Jan 26, 2013 | Ovens
F1-7 errror code Jenn-Air JDS9860P
That is suppose to mean the electronic control 'thinks' the control keypad is not connected.
If it really is connected securely and making good contact, than there may be a problem in the control keypad or the part of the electronic control that detects the keyboard connection. In the first case the control panel would need to be replaced to correct the condition, in the second, the electronic control.
I would think the control panel or its connection might be most suspect though.
Have you tried disconnecting power from the appliance for a minute or two to see if maybe the control would reset?
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Ovens
Oven self-cleans but won't bake. the burners and the broiler both work.
Try turning off the breaker or unplugging the unit for a few minutes and let the electronics reset. If this doesn't correct the problem, then it appears you have a problem with the ribbon cable connection between the oven and the keyboard or a key sticking on the keyboard or a bad keyboard or a bad control module. These should probably be inspected and repaired by a qualified technician, if the reset doesn't work. Hope this helps!
Nov 23, 2010 | GE 30 In Freestanding Gas Range ...
Induction BOSCH E: PIE675T01E displays an error ''Er 22'' and othertimes ''EEEEE''
You have to change a keyboard controller.
Bosch part number 425084.
I had the same problem, I fixed it by replacing this part.
It takes you about 10 min to replace it.
Jan 12, 2010 | Bosch Ovens
F7 is beeping constantly...fan is also running
We had a similar issue. I assume you have the touch pad keyboard. If you clean this with a rug that produces static it will cause a problem with the touch pad. I replaced ours and it is now working again. You can get this part at repairClinic.com. Our p/n for this was
1008902 Touchpad & control panel assembly (Black) 1 $173.10 $173.10
but make sure you check for the correct part/number to fit your oven! Make sure you disconnect power from the oven before you disassemble anything!
I was very happy with the service from repairClinic.com. I can highly recommend using them!
Dec 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Jul 08, 2008 | Whirlpool RBD305PDS Electric Double Oven
Ovens
The F1 error message usually means a short somewhere in the touch panel keyboard. There has been a rash of problems with keyboards. Most of the time there is a simple fix that can be used. Please see my post of April 14, 2007 in response to the problem posted by OVENMAN on April 12, 2007. There you will find a suggested solution which has helped hundreds of folks who have had error messages with GE and Kenmore ovens. If this fix doesn't work, you will need a replacement touch panel. There is no practical way to repair the keyboard in ovens.
Apr 17, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
