Question about Frigidaire Refrigerators
Only the upper ice storage unit will cool. Freezer and Fridge will not. High temp warning and all else works.
Fridge not very old, all clean and appears to be running. Compressor warm.
    Top Expert:
  • Frigidaire Master
  • 47,768 Answers
Call the freon service man
Posted on Apr 20, 2015
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
FRIDGE OK FREEZER NOTWORKING RED WARNING LIGHT ON
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 03, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Refrigerators Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
