Question about Homelite Garden
Trying to use a husqvarna T25 head on my homelite weedeater but will not fit what do I need to do for it to work??
    Top Expert:
  • Homelite Master
  • 44,260 Answers
It never will fit
Posted on Apr 20, 2015
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Stringing a husqvarna weedeater
The 125LD had a T25 bump feed trimmer head, depress with finger and thumb the tabs either side of the head, the base will then pull away with the white centre spool, take a lenght of 2mm cord, bend in the middle so as you have two equal lengths, hook the bent end into the cut a way in the spool and wind both lengths in the same direction as indicated on the spool, once you have enough cord on the spool secure the ends in the slots on the outer edge of the spool to stop it all un raviling, place the spool back into the spool housing, carefully place the cord through the metal eyelets, push the assembly back into the upper housing clicking it back into position.
Jul 05, 2012 | Husqvarna 128 LD Weedeater
Fuel line on husqvarna weedeater need replaced
They are just a pull/push fit. The fuel line has 2 flanges that should fit either side on the fuel tank. Pretty simple to replace.
May 12, 2012 | Husqvarna 28cc Gas Line Trimmer
Need to know if the adjustment screws on a Homelite Bandit UT10901B carb are adjustable--it does not have the plastic limiter caps I am used to seeing--now I know why I like to work on Stihl or Husqvarna
The Homelite Walbro carburetors use 'D' headed screws for the jets. A 'D' head screwdriver is necessary, although a thin-wall piece of brass tubing (from a hobby shop) that force-fits over the heads will probably work. Hope this helps!
Jan 29, 2011 | Homelite Garden
Unable to base the cord on my homelite 26ss weedeater
as soon as i pull on the cord it comes out of plase
Jul 17, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
I cannot remove head from my Homelite weedeater
Make sure you're turning it the right way: some models use a left-handed screw, which you turn clockwise to loosen.
They can get very stiff, too, so try a strap wrench or locking pliers
Apr 21, 2009 | Homelite Garden
Garden Logo
64 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
