Question about Coffee Makers & Espresso Machines
Where do the two little springs go on a grind and brew glass decanter cuisanart
    Top Expert:
  • Coffee Maker... Master
  • 45,204 Answers
Maybe on the LID
Posted on Apr 20, 2015
Cruisinart grind and brew problem with auto shut off
may auto shutoff problems with Cuisanart coffee makers can be resoilved by unplugging the unit for about an hour. That will allow its internal computer to reset itself.
Feb 19, 2015 | Cuisinart Coffee Makers & Espresso...
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
Having a problem with the mix. In the disposed grind container I am getting a lot of water mixed in with the grinds. Tried to clean screen and a glass bead fell out. I am assuming this came out of the...
The glass bead is part of the pressure system. It goes under the long tapered spring. The bead goes in first, then the small end of the spring, then the Oring goes around the spring on the plastic part of the head. Then the manifold goes on with the L shaped tube going towards the handle side. Hold down the manifold when you puty the screws in.
water in the dredge drawer is a sign of a coarse grind. The finer the grind the less water in the dredge drawer. Don't go too fine or you will be cleaning the brew head a lot.
Nov 09, 2010 | Saeco Vienna SuperAutomatica Coffee...
The clock works but nothing else, could it be programed and I need to reset? how do I reset? I am talking about a cuisanart grind and brew.
there are thermal protection switches under the warming plate there is usually 2 of them if one blows it will stop all function but usually not clock. youcan fix them yourself youfirst need to remove bottom to get under warming plate and there will be two little bullet shapped fuses made from copper youcan use a test meter to see if there is current passing through them both fuses must pass current through to work if one is bad and other is good it will not work . you can aquire the fuses on the web just do a google search for inline thermal protection switch and type name of pot or maker you have to get right ones .. but let me warn yout these are in place for a reason they usually only blow when there is a problem usually overheating problem . so it may be a wise choice to just replace product.just incase
Mar 17, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
The coffee maker over flows with coffee
You might have to reprogram the brew level. Does it over fill the decanter or is is over flowing from the brew basket?
If from the decanter then reprogram, there are instructions behind the front panel.
If from the brew basket then adjust coffee grind and or volume, also check and clean the sprayhead.
Jul 14, 2009 | Bunn CWTF35-3- Stainless Steel
Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Mar 18, 2009 | Gaggia Titanium Espresso Machine
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Spacemaker? Digital Coffeemaker-overflows during brewing with grounds everywhere.
I've read of this problem from other users of the newer Spacemakers and believe I know what's going on. Black & Decker used too strong a spring in the mechanisms involved in the "sneak a cup" feature which keeps the small tab or finger underneath the basket from opening and allowing the coffee to run into the decanter.
My suggestion would be to make certain that the tab that presses against the bottom of the basket is open when you insert the carafe. Not owning one of these units I can't state categorically that this will solve your problem, but all of the Spacemakers are fundamentally the same, just some cosmetic and design differences between them.
If it turns out that the tab is open when you go to bed and the basket still overflows it's possible the spring is so strong that it's moving the carafe away from the back of the unit, causing the tab to close against the basket. If that's the case I would figure out how to remove the spring without breaking anything in the process, then take it down to your local Ace Hardware and get a same sized but weaker spring. That should solve the problem permanently.
Sep 14, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
