Question about LG Washing Machines
No error codes, but machine overfills with cold pre-wash water even when the function is not selected. Two problems in one: overfilling and wrong function activating. What should I do?
My friend gave me an old LG washing machine because it was not filling with water properly slow or not at all. I purchased a level switch, cleaned the inlet valves and hoses, and that problem seemed to be resolved. No error codes were ever observed. Unfortunately, now that the water is flowing normally again, I see that water from the pre-wash hose fills the machine even when the function is not selected I had it on hot/cold, no pre-wash. By the time the hot water kicks in and pre-wash cold water stops, the machine is already overfilled. My friend says this was not happening before. So, not only the pre-wash cold water hose is letting water in when it shouldn't, but also the machine is not telling it to stop when the machine is overfilled. I tested both inlet valves with a multimeter and, electrically, they are working properly. Any ideas on what I need to do next? Thank you!
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Check entire electrical circuitry for loose or damaged wires that connect to the main control board.
Posted on Apr 21, 2015
    Genius:
  • LG Master
  • 1,585 Answers
Pressour switch
My LG model WM1812CW washing machine is leaking water and says FE in the display
problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
Jan 26, 2014 | LG Washing Machines
Code letters FL comes up and makes clicking sound
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Oct 17, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I have a kenmore elite washer and a error code fl keeps comming up and wont continue washing
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 02, 2010 | Kenmore 24032\24036 Top Load Washer
Does the machine have to be full to function properly and what does FL mean.
Flood Condition:
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#!@
May 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is error code flashing Fl represent? Can you just fill the tub with water from an external source and expect the machine to go into wash cycle by preesing start? Does the tub have to fill throug pump...
Flood Condition:
Jan 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso SM9710976A has "FL" on front panel. Whats wrong?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^!!$#
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
My maytag neptune mah550bww will not start up , gives a code FL
Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code. Remove this piece to see if it helps.
If this is a new installation - check that the hoses arent reversed (cold on hot and hot on cold). This will also cause the FL error.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine overfills with water at start up after two years in use.
If the washing machine operates and cycles correctly, and only problem is overfills, then you have a bad water level switch or a bad membrane sensor (water level sensor).
If instead the machine get stuck on filling, and does not stop even if you advance timer, then the inlet valve is stuck on open, or the control board is faulty.
If machine is only two years old, call manufacturer and complain, even id limited warranty is one year, they may cover the part cost the same if they decide this was a factory defect (if it is inlet valve) coming up after two years.
Mar 17, 2009 | Whirlpool Washing Machines
My calypso stoped and FL flashes and will not cancel,
Flood Condition:
Feb 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Washing Machines Logo
69 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
