Question about Cub Cadet Garden
Blade wont operate - Cub Cadet Garden
  • 601 Answers
Check your belt and pullies for wear. Replace as needed. GOOD LUCK FRIEND.
Posted on Apr 22, 2015
Yanmar b15 excavator Boom and arm will not operate. everything else works fine. HELP.
Is there an interlock on the boom that wont allow it to operate if the front blade is not set? There could be an issue with hydraulic fluid, pump or PTO.
Feb 08, 2017 | Cars & Trucks
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
Get blade rotor to tighten correctly
1. does the spindle turn freely without the blade attached?
2. is the spindle housing tight against the deck with the mounting bolts tight. If not, check to make sure the housing isnt cracked.
Oct 05, 2014 | Craftsman Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
2000 jetta wipers wont work
Washer fluid is probably frozen, have you checked the fuse for the wipers? There should be an overload protection in case the blades stick
HTH
Jan 15, 2013 | 2000 Volkswagen Jetta TDI
Blades wont turn on club cadet 50
hi
you may have broken wires to you electrical PTO clutch that connects the blades to operate its below the engine attached to the bottom shaft if your clutch is burned you need new one with the engine off sit on the seat and engage blades with the switch if you hear a clicking noise it is working and maybe your belt has broken off carefull of blades
Joe
Sep 11, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Every time I use the lever to get the blades started it kills the engine. it does it even after i removed the belt. what is causing the blade rotation lever to kill the engine?
hi there talane
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector then retry then check blade engagement switch may be playing up or a nuetral switch playing up but more likely a seat switch
with operator off seat and park brake on engine runs, but with pk brake off and operator off seat
engine stops , same if operator leaves seat and blades engages -engine stops,
if unit not in nuetral and pk brake not on unit wont start
take look
hope it helps
cheers pauly46
Jul 03, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hi have a Toro wheelhorse 212-6. new to us. wont cut.
Yes, there is a switch on the dash. It operates an electric PTO or clutch for the mower blades. That is how most lawn tractors work. Of course , yours could be different, but if it is, It still has a clutch somewhere and a lever to engage the blades. Most of the electric ones are controlled by safety switches, One being in the seat, if you are not in the seat, it will not connect, if you get out of the seat with it running, the engine will cut off. Sometimes one is on the mowing deck, it will not connect if the deck is up. If you cannot get the PTO to work, it could be shot. (Rare) You can hear it go when it starts, check it out, hope this helps.
Jun 06, 2010 | Garden
Craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Jun 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
