Question about Radio Communications
Why wont it play through my PA system - Radio Communications
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
The radio won't play because it a PA system . just like a bullhorn. But if you connect it to your external speaker with a jumper it should work.
Posted on Jun 18, 2015
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
CB in Receive Mode Plays Out the PA Speaker
no,its supposed to work that way so you can monitor it while you are outside your vehicle.
Are you following the user manual that came with the radio?
NB-ANL/CB/PA SWITCH: When the switch is in the NB/ANL position, the Noise Blanker (NB) and Automatic Noise Limiter (ANL) circuits are activated.
The Noise Blanker is very effective in eliminating repetitive impulse noise such as ignition interference. In the CB position, the PA function is disabled and the radio will transmit and receive on the speaker that is connected. In the PA position,
the radio acts as public address amplifier. Your voice will come out of the speaker that is plugged into the PA. SP. jack on the rear panel. The radio does not operate when you are in the PA mode.
When you plug a speaker into the ext. jack does it kill the radios internal speaker? It should until you unplug it; if not and you are following the about you may have a wiring issue with the jacks.
Pa speaker has cb channel playing on it not my voice
do you have speakers hookd into both the ext and pa connectors in the back of the the radio? If not try it , it should work.
Apr 18, 2014 | Uniden Bearcat 880 CB Radio with 7 Color...
My pa system recieves signal but wont send any sound out
Check cables to speakers from amp if any. Possible crossover or channel failure.
Apr 08, 2014 | Audio Players & Recorders
Yamaha Msr250 (10" Biamped PA Speaker) It's like new, possibly even new but I can not figure out why the sub will not play. The PA horn works and plays high treble. I see 3 good fuses on the board
Remove the back, follow the 10" speaker wires and check if you can see any obvious bad solder. If you find a bad solder just resolder it and give it a try. You can also check for burnt discrete components like capacitors.
Oct 18, 2012 | Yamaha MSR250 Speaker System
Lost manual. I need to know how to hook a TDK-3826 dual recorder to a PA System at church to record the services and what CDs to use.
Hi wpless43!
The TDK-3826 supports analog input/output, digital coaxail input/output, and digital optical input/output. To connect a PA system, you'll have to determine what type of connection it uses. If your PA system uses an analog connection, it will have two audio cables, one for the left sound channel and one for the right channel. These are color coded and can be connected to analog connections on the back of recorder. Coaxail and optical connections are both single cable connections, and can be connected to their respective locations on the back of the recorder.
Regardless of the connection used, you'll want to connect one of the outputs of the PA system to the recorder if you want record. If you want to use the recorder to play back audio over the PA, you'll want to connect the output of the recorder to the input of your PA. Most PAs support multiple outputs and inputs, so you should be able to connect the recorder input and output at the same time.
You'll want to use CD-R/RW discs to record, but make sure they are audio discs (See image). joehaydu.jpg
You can find a copy of the manual for the TDK-3826 at http://audio.manualsonline.com/mdownloads/bd4c0d62-6f82-4bfb-bf83-8d832f3fe222.pdf. Hope that helps!
Mar 05, 2011 | Computers & Internet
I want to play my tascam guitar trainer through my yamaha pa. will there be any impedance problems . Want to use this as background music, howecer have little knowledge about pa systems. thanks
You'll be just fine. The Yamaha PA inputs are able to take high or low impedance inputs via the Line-In (1/4") input.
I would not recommend plugging your trainer into the mic level (XLR) input. The preamp will be fine, but you'll have to turn the gain so low that you'll be in the nonlinear part of the gain circuit, and the sound quality will suffer.
If that helps, hit the "thumbs-up" for me. If you have other questions, or if I can explain further, just post-back and I'll see what I can do.
Dec 23, 2009 | Yamaha Emx88s Powered PA Mixer System
Radio Communications Logo
135 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
