Question about RCA RS2653 Shelf System
How to make cd hanger stop skipping, plays part of one then skips to the next CD and does the same thing
I put in 5 disk and only plays half of one then skips to the next.
    Top Expert:
  • RCA Master
  • 52,123 Answers
Only a guess but the infra red eye possibly needs cleaned
Posted on May 02, 2015
  • Charlotte English
    Charlotte English May 02, 2015
    Thanks Ray, will check it out.
Kimi
  • 277 Answers
SOURCE: cd player
RCA has had lots of bad laser pickups the past several years. It has to focus before it will spin. Sometimes they will focus and spin but still not read the disc. Unfortunatly that unit is a throw away and no parts or service literature is available from RCA/Thomson. So if cleaning it does not do it, you are probably out of luck. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Posted on Dec 18, 2005
SOURCE: RS2635 5 disk changer skipping
your cdplayer is probably at intro
Posted on Aug 08, 2007
  • 4234 Answers
SOURCE: rca rs2656 5 disc unit
Those "cleaning" discs are rarely effective. Open up the unit cna carefully clean the lens using a cotton swab and alcohol. Update this if that failes to resolve the problem.
Dan
Posted on Mar 26, 2008
  • 15 Answers
SOURCE: RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Posted on Jun 24, 2008
SOURCE: cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Posted on Oct 15, 2008
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
My Bose stereo CD player skips when I put on a cd. Doesn't matter if I change cd or advance track. After 5 min. it stops skipping, then no problems until next time I turn it on.
Bummer deal! Sounds like a lube problem. Maybe its an age thing. My car player does just the reverse. The arm hinge is the problem. Try wd40 with a straw, sprawing into the disk area, using a cd you don't mind losing to see if this tip works. http://www.auto-tune-up-and-repair-options.com/Mega-Power-120-lube-spray.html
Dec 05, 2016 | Bose Audio Players & Recorders
The cd skips When I put a new cd in, it begins at one then skips to much higher numbers. I have cleaned the cd. Used a laser cleaner disk and I do not know what else to do. Am very frustrated. I have dried...
The "read-ahead" memory cache is too short.
Not much you can do, short of replacing the player; however:
Does your CD player support playing MP3's?
Convert your Audio music CD's to MP3.
The same audio music is "smaller" in MP3 format than audio format. More of the song can fit in the memory cache so it is less likely to "run out" of mermory and skip.
Oct 13, 2009 | 2004 Toyota Sienna
2000 Nissan Maxima GXE: CD player issues
The laser assembly has lost its ability to focus on disk surface. Replacement of unit is in order/repair not cost effective.
Jun 20, 2017 | 2000 Nissan Maxima
Honda Civic EX 2001 CD Player
Try to use a cleaning cd to clean the cd player otherwise it may be about time for your cd player to die
Feb 18, 2009 | 2001 Honda Civic
Every disc in tray ends with noise after a minute
Try a cd cleaning disc, the ones you can buy with the small cleaning brushes on them! It sounds like the laser is dirty.
Sep 13, 2007 | RCA RS2640 CD Shelf System
Aug 05, 2007 | RCA RS2635 CD Shelf System
Cd's player wont work quite right
u need to manually clean the lens using cotton buds(no fluid or solution) extra care! hope this help u...
May 15, 2007 | Jensen MP5610 CD Player
RCA RS2653 Shelf System Logo
249 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
