Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
The heated drying cycle no longer dries -- what should I check in the heater coil circuit?
    New Friend:
  • 39 Answers
More than likely the heater element is shot.
Posted on Apr 20, 2015
The "clean" light blinks 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
My GE Dryer is not drying my clothes completely on the first cycle but when I feel inside the dryer it feels hot? Do you have an idea of what could be the issue Model# DJXR433EG1WW
If your dryer still heats, but your clothes take longer than usual to dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Exhaust ducting that runs to the attic is usually the worst configuration, because the air has to be forced up. The blower fan will meet more resistance and any lint that does not exhaust completely, ends up stuck in the vent. Water appearing in the drum is another sign that you have a clog somewhere causing condensation to develop. FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this is generally a sign that the heating element IS working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat. If you have any questions, please post back and let me know. I hope you find this information helpful.
May 19, 2011 | GE DBXR463EDWW Electric Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
MDB6160AWW - flashing lights after hitting the normal cycle: Clean and Heated Dry buttons flash. What is this code telling me? Keith
Hi
These blinking lights indicates an issue with heater circuit, door switch or wash pump. Please reset the power to the dishwasher and after, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 18, 2011 | Maytag 24 in. MDB6100A Built-in Dishwasher
The "clean" led flashes and
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | Kenmore Dishwashers
TAKES 2 TO 3 CYCLES TO DRY. gETS BARELY WARM
If your dryer is still heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 08, 2010 | Roper REX4634KQ Electric Dryer
The clean light keeps blinking and won't run new cycle
Whirlpool & Kitchen-Aid
Tall Tub Dishwashers
PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
Control is programmed to stop running and not allow any further
cycles if it detects a water heating problem (no temperature
increase detected in heated Main Wash cycle or in 3 consecutive
cycles on the latest software version). Control blinks the Clean
LED 7 times repeatedly and disables the Start/Resume key until
cleared.
Running Diagnostics clears the control and allows it
to operate again. The water heating condition
must be corrected or the control will stop
running again. See potential causes below.
Check If…
Heater circuit problem:
♦ Open heater.
♦ Wire disconnected, open connection or component
in heater circuit.
♦ Faulty heater drive circuit on control.
Then…
1. Check operation of heater in Diagnostics cycle.
2. Unplug dishwasher or disconnect power.
3. Check resistance of heater and all components
and connections in the water heating circuit or heat
dry circuit.
Door switch not making contact consistently:
♦ Misaligned door latch assembly (which can be
aggravated by high door closure force keeping
strike plate from fully seating).
♦ Faulty door switch (high resistance).
♦ Loose or missing installation anchor screws,
causing tank to shift in cut-out.
NOTE: Neutral switch on plastic tub models is only in series with
the heater; other loads are not affected.
1. Unplug dishwasher or disconnect power.
2. Measure resistance of door switch contacts while
checking mechanical operation of latch assembly.
Confirm switches not loose from assembly. Check
strike plate and door closure.
Wash pump not pumping water past the heater efficiently.
• Foreign object in pump
• Excessive foaming
• Clogged pump screen or broken chopper screen
• Loose electrical connection in motor circuit
See Tech Sheet “WASH PUMP WILL NOT PUMP”.
Lack of water to heat. (Unit not filling properly)
• Insufficient water supply pressure
• Fill valve screen blocked or valve not opening fully
• Loose electrical connection on Fill Valve.
• Float switch obstructed or functioning abnormally
See Tech Sheet “WILL NOT FILL OR LOW
WATER”.
Diagnostic Key Dance:
HOPE THIS HELP
Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
My dryer takes a long time to dry the heater kicks on and off intermittantly
A dryer is supposed to kick on and off intermittently as its dries. The heating circuits are regulated by a thermostat that will turn the element on or off as the cycle progresses. It also works in conjunction with a humidity sensor (if equipped with an "Auto-Dry" feature) to increase or decrease the heat depending upon the moisture level in the drum.
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
Jan 13, 2010 | Dryers
Hi, My Indesit WIDL 102 is faulty. It washes OK, But does not dry at all. I dont think it heats up during the drying time, but the drum does turn round. Is there a thermal reset switch on the inside...
I don't know your dryer model, but I assume it is electric. Electric dryers have a heater coil like a toaster which eventually wears out and doesn't get hot anymore. This is typical and is likely the case especially if your dryer is old or has been used alot. Has the dryer been taking longer and longer to dry before it lost all heat? If so, I bet it is the heater coil.
Feb 28, 2008 | Dryers
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
74 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
