Question about Pioneer Audio Players & Recorders
Is there a pioneer location to service my receiver?
Receiver works fine, but dusty inside of unit. Don't want to take chance cleaning myself..
  • 4234 Answers
SOURCE: Pioneer VSX-D702s receiver - no sound - need help/circuit plan
The unit is in what is called "protect" mode. A problem was detected in the final output stage and that stage is turned off. The most common reason for this is failed output transistors. This is a simple repair for any repair shop and will cost about $10-$15 for parts plus the local labor charge. Expect that the output transistors plus a few supporting parts to be replaced. Most of the time, only one channel is badm, but due to the design of the protection circuit, both channels are turned off.
Dan
Posted on Apr 01, 2008
SOURCE: Onkyo receiver audio problem
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1 button, press Speaker A.
4. You should see "CLEAR" on the display for a second and the unit will go on stand-by mode.
5. Turn on the unit again and check if sound is back.
Hope this helps.
Posted on Jul 07, 2008
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
dthomas1969
  • 4 Answers
SOURCE: Owner's Manual - Pioneer VSX 455 Receiver
It should be compatible with all of them. I have one that works just fine with my Sony HD/TV, HD DVD PLAYER, etc. The only difference is that its is stereo w/ a middle speaker hook up, if you so desire.
I find it just as enjoyable and easy to use as my Denon 6.1 with fewer speakers. That is because as men, our hearing range is poorer especially as we grow older.
Email me with any other concerns you may have.
Thanks,
dthomas
Chicago, IL
dbondick@comcast.net
Posted on Feb 07, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
I have a pioneer VSX-1016V receiver and after a while the right back surround speaker stops working . I have also noticed that the cooling fan inside does not start either and the unit gets hot.
Sounds like its power amplifier circuit has the fault. Contact any service technician. Make sure that the fan works properly; otherwise further damage will surely occur due to overheating. The circuit seems to be much complicated. Contact any experienced service technician. The work cannot be performed by a normal user, I should say.
Jul 18, 2016 | Pioneer Audio Players & Recorders
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Pioneer VSX-D412 directv remote code
I also have the VSX D412 and DirectTV. My DirectTV remote controls the D412 fine, but I did have the same problem you're experiecing with a Sylvania flat screen that the remote wouldn't operate. I corrected my problem by turning the TV off, then back on using the TV's remote, then telling the DirectTV system that I didn't know the model number and let the system search for the code. Hope this helps.
Feb 17, 2012 | Pioneer VSX-D412 Receiver
I have a Pioneervsx-1021k AV Receiver and all the buttons were working fine until I decided to play with the remote. Now some of the buttons light up, and some don't. I have found that not being able...
Hello
Just reset the system and try. So many external commands may confuse the system control IC inside, will hang up very like our computer systmes do. Resetting it to factory settings will make the unit work well. To reset the system:
Disconnect the iPod and USB memory
device from the receiver beforehand
1# Switch the receiver into standby.
2# While holding down ENTER on the front
panel, press STANDBY/ON.
The display shows RESET .
3# Select 'RESET' using PRESET then
press ENTER on the front panel.
The display shows RESET? OK.
4# Press ENTER to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory default settings.
Note that all settings will be saved, even if
the receiver is unplugged.
If this process does not help you, your system needs service with its main system control circuit. Actually this is a very skilled job, and should be done either by any well experienced service technician or by the Authorised Service Center for Pioneer at your town. OK.
Aug 21, 2011 | Pioneer VSX1020K Receiver
I have a 2 year old Pioneer VSX-819H-K that only recognized the remote signal from about 2 feet away. Worked fine last night. Changed out the remote batteries three times, then programed a Cox...
hi,
You have to order for the IR receiver module for the system. Also check inside the frond panel of the system is there is any durst accumulated in frond of the IR receiver unit.
ok
May 07, 2011 | Pioneer VSX819HK 5 Channels Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
Wired it wrong and there was a little smoke from the stereo system. now it doesnt work. Anything i can do about it??
Smoke coming from electronics is never a good thing. If it was working or new before you wired it wrong, chances are it isn't something you could fix without the knowledge and proper test equipment to pinpoint what was fried. There are no user serviceable parts inside the unit. You can send it out for repair or get another one.
Apr 21, 2009 | Pioneer DEH-P2900MP CD Receiver...
DEH-960MP CAR CD PLAYER STEREO RECEIVER DISPLAY PROBLEM
its the ribbon wire inside i have the same deck with the same problem and it cost me 100$ to have it fixed since the warranty was no longer valid any pioneer repair place can do this for you. All you need to do is take them the head unit not the wiring harness so at least you dont have to unhook it all
Mar 14, 2009 | Audio Players & Recorders
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
