Question about Estate ETW4400XQ Top Load Washer
Fills up with water, but will not run? - Estate ETW4400XQ Top Load Washer
    Genius:
  • Estate Master
  • 1,585 Answers
Check dorr inter lock
Posted on Apr 21, 2015
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
My LG washer/dyer fills up with water after its done running, it washes and drys then fills up
something is holding the input valve open small pieces of rust etc. will do this .that is why they put screens in the ends of the hoses
Sep 23, 2017 | Washing Machines
WATER FILLS WONT SHUT OFF
The pressure swith (load size) is what controls that chang that. A small hose runs from the bottom of your tub and as the water fills a measerd amount of water fills that tube and pressure build up in their operates that switch and activates the timer to stop filling and start agitating.
Jun 06, 2010 | Kenmore 24032\24036 Top Load Washer
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
After flushing, water fills up tank and continues
Your problem is the water fill valve. Check this link.http://www.rd.com/17646/article17646.html
it's not the flapper or flush valve.
Mar 05, 2010 | Home
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water runs out of the water in the door when the ice maker fills
It is possible that your icemaker tray is overfilling and the excess water is running out of the ice chute. There is an adjustment screw on the icemaker head beneath the large white cover which can be adjusted to compensate for this. If not then the icemaker head may need to be changed to correct this.
Mar 09, 2007 | Amana SXD524VW Side by Side Refrigerator
Estate ETW4400XQ Top Load Washer Logo
54 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
