Question about Crafts & Hobbies
Hi my ex is on a pension bus pass can he us this on the trains after 930 i know on the buses it free after 930am but not sure about the trains
Hi i would like to know are there any buses traveling to international places like Lesotho?
look up schedules of bus companies and transport agencies in your area and destination area
May 10, 2017 | Cars & Trucks
Online centrelink
First you must wrestle 2 crocadiles.
May 07, 2013 | Cars & Trucks
Bus Times
Sure...............Instead of keeping this as a Product Support website, let's just run the bus schedule too................
Need the weather forecast?
Apr 11, 2013 | Computers & Internet
What are buses when talking about network cards?
The paths taken by data moving with a computer are called "buses". Multiple side-by-side paths force data to move in parallel, and not in series (one after another).
Feb 14, 2013 | Computers & Internet
Hey!....I wanted upgrade my storage fro floppy 2 zip..... Would like 2 know how can I go about switching the out.....thanks in advance tucunn
Did you post this in 1996? Floppy drives use a different parallel bus than a Zip drive it's 34 pin vs. 40 pin for the zip drive, if I recall (from 15 years ago), so unless you have a motherboard with a free IDE bus you aren't going to be able to do it. Most motherboards have two 40pin IDE buses capable of driving 4 devices (two per bus), so check how many CD and hard drives are in your machine (or check the bios) to see if you have a free bus. Also, a lot of Zip drives were SCSI (which would be either 25 or 50 pin), in which case you are going to need a SCSI card.
Feb 28, 2011 | Computers & Internet
To much play in steering
There are a few things that could be wrong.
1) One of the suspension joints are worn and causing the excessive play, ie....tie-rods, idler arm and so on.
2) Steering gear is worn and in need of adjustment.
All in all, they should take a look at it and determine if anything is out of spec.
I know school buses are required to pass state inspections, has your bus been checked lately?
Good luck.
Mar 26, 2009 | 1995 Chevrolet C2500
FM TANSMITTERS IS NOT WORKING PROPERLY
Hey basically it should work even if u are in a bus or train.But the only thing it get troubles is when u are around a Big mountains/hills etc.observe it when u travel next time.
I guess so.
Jan 28, 2009 | Sony Ericsson K550i Cellular Phone
Wiring a 3 wire dryer wire into panel box
Stick her under the neutral buse, the groung and the neutral are connect at the panel anyway.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Crafts & Hobbies Logo
376 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
