Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel leaks when refiling.
Is it fixable
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Probably the fuel line has deteriorated and is cracked allowing fuel spillage. A remote possibility is the tank itself could be split.....remote though. Yes there are replacement fuel lines for most saws, some are OEM and have built in grommets to seal the connection into the fuel tank and some use standard fuel lines that can be cut to length and slipped over barbed fittings on the tank and carb.
You probably have to take it to a service center to have it done unless you like to tinker with dirty, oily, smelly and generally grimey power tools on your workbench or kitchen table.
Try Jacks Small Engines to find your parts. Have your model and serial number ready as you'll need it to get info out of their parts locater.
Posted on Apr 21, 2015
Seller says that it leaks fuel, is this a known problem ?
fuel leaks could be from split tank ,damaged tank fittings , hoses , faulty in carby
The seller is advising you of a problem with the fuel system of the bike as he has to by law
There are too many bikes of this make to have a manufacturers fault
Ring a bike shop that sells the brand and ask them direct what the problems, if any, are with the bike as the seller may be focusing you on a fixable problem and not reporting a more serious fault
Remember the saying --buyer be ware --so if possible you should inspect the bike personally and see what the problems are and run it your self
Feb 27, 2016 | 2012 Moto Guzzi Stelvio 1200 NTX
CARBURETOR LEAKING OIL AND SMOKING
IT is likely that the carb is leaking fuel and filling the crankcase with fuel. Causing excessive crankcase pressure forcing oil into airbox through the crankcase vent. Check your crankcase for fuel and/ or being overfilled. If fuel is present fix the carb first, then drain and refill crankcase. After all is fixed run the unit outside for a few minutes and let it burn off excess smoke.
Sep 02, 2014 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Front oil leak by the oil filter and the oil coolant part
Maybe a blown gasket or blocked engine breather pipe.
May 17, 2014 | Mercedes-Benz Cars & Trucks
Ford f650 xl super duty will not start. replaced fuel filter. drained fuel bowl to fuel filter. It will not refill. checked all fuses, circuit breakers and relays. they are good. flushed fuel lines with...
If the fuel filter will not refill, you know you have a fuel problem. Some of the fuel systems use a "pull" system unlike gasoline engines using a "push" system with a rear fuel pump.
The "pull" systems need Vacuum in the fuel system to allow a draw from the tank. An opening at any point in the system will defeat the drawing of fuel. What you might try is a Vacuum pump attached to the fuel line at various intersections in the flow.
At the point of the air leak, you should find that you can not draw fuel past that area without "losing the prime". You also may want to fill the new fuel filter to reduce any air pockets in the system. I can not say if your system has a fuel pressure regulator, but a leak in its diaphragm can affect starting. Also if the air pressure was excessive, the diaphragm may have ruptured.
Please rate my info.
Jan 31, 2014 | 2000 Ford F350 Super Duty Super Cab
What is p 0455 mean?
P0455 Evaporative emmission control leak (gross leak). Here is the main possiblity the gas cap is out, or you filled up the fuel tank with the car running, because its a large leak you can visually inspect the fuel refill hose, If you have a shop that can inspect this for you they can find it .
Apr 27, 2011 | 2004 Suzuki Forenza
Hot water tank leaks, big time, as it refills, stops dripping
If the leak is from the tank itself, no you can not fix it. If it is a supply pipe and the leak is visible, in most cases yes. I would recommend you have this issue resolved very soon. If the tank has sprung a leak, it will be a matter of time before the leak becomes a flood.
Feb 03, 2010 | Plumbing
Ammonia smell coming from fridge, can it be repaired?
Yes, it's fixable. The refrigerant is leaking. Leak would be found, repaired, system recharged.
May 27, 2009 | Electrolux Refrigerators
2007 Kia Spectra changed oil, gas is in old oil, fixable?
leaking fuel pump or a leaking head gasket.  Take it back to the dealer.
Mar 12, 2009 | 2007 Kia Spectra LX Sedan
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
62 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
