Question about IBM Wheelwriter 3500 By Lexmark Electric Typewriter working
The code DL PRT comes up on bottom left corner of screen on IBM Wheelwriter 3500 by Lexmark and machine will not type correctly until I can remove the code but I don't know how to remove this code.
A long Code key on machine is used with different command codes listed on different keys below the alphabetical letter on keyboard. The DL PRT code is not listed on any of the keys and it comes on by accident and I can never figure out how and I cannot remember how to cut this code off.
  • IBM Master
  • 3,594 Answers
On the upper right hand of the key board is a key labeled print mode press that key to exit that mode.
DickyO
Posted on Apr 21, 2015
How to clear DL PRT
depress the button on the far right panel that says print.
Feb 11, 2016 | IBM Wheelwriter 3500 By Lexmark Electric...
I have a a Lexmark Wheelwriter 3500 and it has the delayed printing function, well this does not seem to be working correctly it is typing before it should. what can i do to correct this problem?
If it types as you press the kets delay print is turned off, press the print mode key on the r
R. side until Dl prt is on the display. If it just starts typing at a the same position every time you probably have the R. margin set there and auto return on (CODE R).
DickyO
Jul 27, 2011 | Lexmark Wheelwriter 3500 Typewriter
Help! I cannot get my typewriter to work properly...here is what I get: left hand display says "DL PRT CONT" right hand display says "LO-BAT" I want to canel all the above,...
DL PRT ca be turned off with the print mode key on the R. side of the keyboard.
The batteries need replaced. They are located just beyond the keyboard on the base, 2 or 3 batt. on either the L. or R. of the PC board. Be sure to clean the contacts in the holder.
DickyO
Dec 08, 2010 | Lexmark Wheelwriter 35 Series II...
The DL PRT appears on the LCD screen and I cannot type.
On thr R. hand side of thr keyboard is a print mode key press it and delayed print should go out.
DickyO
Feb 17, 2009 | Lexmark Wheelwriter 3500 Typewriter
Faint printing on checks
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Feb 02, 2009 | Lexmark Wheelwriter 3500 Typewriter
Wheelwriter 3500 KYBD 099
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
IBM WheelWriter 3500
Try pressing and holding code key while pressing "L" release "L"
and type 001 release the code key. If this solves the trouble but it comes back on the next power up the keyboard is bad.
DickyO
Mar 25, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 3500 By Lexmark Electric Typewriter working Logo
98 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
