Question about Maytag Washing Machines
I have a maytag clothes washer, fills with water, can hear clicking in button but doesn't start agitating immediately. When load has finished we find caked soap on clothes.
    Genius:
  • Maytag Master
  • 1,585 Answers
Needs a good cleaning put on the high temp and run through use a descaler
Posted on Apr 21, 2015
Why does my maytag yop loading centennial washer sometimes spin and sometimes not?I can move the washer cycle knob to different cycles and I will still have the same problem
I had the same problem kinda. Does it start to agitate before it fills with water? Its supposed to fill with water, agitate, sense the amount of the load, then fill with the correct amount of water. If it agitates right away then you need a water level/ temperature control sensor. I replaced mine and no longer have the problem of wet clothes at the end of the cycle. The part number is w10248240. Look on you tube for a video on how to replace. The one I saw showed how to diagnose the sensor. The part cost about $90 and it took longer for me to get out my tools than replacing the part. This part goes bad by starting the machine then adding more clothes after it starts. You can also try blowing air down the tube from the back of the sensor. It didn't work for me but was suggested and blowing the air didn't cost anything.
Apr 23, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer starts agitation during water fill up and after spin cycle ends washer fills back with water and leaves clothes very wet.
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Oct 20, 2010 | Whirlpool WTW5850S Top Load Washer
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Small brown spots on whites
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
