Question about Samsung SGH-t629 Cellular Phone
My fone The screen on my phone is completely fried. Most of it is white but it has some unrecognizable black areas and some faint color lines on a portion of the white screen. None of the screen menus show up and it appears that everything else works (receiving calls, dialing out even though the numbers don't show up_. What should I do and if a repair procedure is presented, where would I get the parts?
  • Chainzz Jan 12, 2008
    Same thing. Finally said screw it, and went back to my Sony w810i. Love that thing!!
    Brigadier General:
  • 7,752 Answers
You need to have the lcd replaced , take it to a mobile service center or professional technician close to you and have iit replaced there.
Posted on Jan 23, 2008
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
Screen is completely white
check with your companuy and reboot your phone
Sep 23, 2009 | Motorola Mobility RAZR V3
Env2 doesnt work
dont sit on your phone buy protcetive case for the phone model and be more carefull and dont trom throw the thing it wiil not help fix the problem k
Aug 27, 2009 | Samsung SGH-E900 Cellular Phone
Docucolor 2045 print White areas
a number of reasons can cause this. have you tried each colour individually? after this swap drums and see if fault moves with the drum. otherwise its probably developer
Jan 21, 2009 | Xerox DocuColor 12 Color Copier
Got 2 faint white lines on screen on philips 42 lcd ambilight
Sounds like plasma burn in. I'm fairly positive this TV has a white out burn in removal in the menu somewhere. Look for it. It should be a program that makes colored static all over the screen or a white scrolling bar followed by black fading into white again. Run it for an hour or so. If that doesn't fix it, there's not much else you can do.
Jan 05, 2009 | Philips 42PF9630A 42 in. Plasma Television
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Oct 05, 2008 | Nokia N73 Cellular Phone
Sidekick id screen
Seems you need a new Lcd assembly i can provide you with one very cheaply please contact me at I can sen you a new Lcd or u can send me the phone for repair
Jul 21, 2008 | T-Mobile Sidekick ID Cellular Phone
HP 7110 still won't print in color
Your post " prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
LCD Screen Fried
Flex cable could be torn. This was the problem when I took my phone apart.
Oct 09, 2007 | Samsung SGH-t629 Cellular Phone
Samsung SGH-t629 Cellular Phone Logo
71 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
