Question about Hotpoint Refrigerators
I have a hotpoint ice diamond model rfa51p and alot pf water is on the fridge what would this to happen
  • Hotpoint Master
  • 5,323 Answers
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
I have a hotpoint ice diamond model rfa51p and alo - hotpoint-ice-diamond-model-rfa51p-alot-iizpua1124tc1voeqjalmrl5-3-0.jpg
hotpoint-ice-diamond-model-rfa51p-alot-iizpua1124tc1voeqjalmrl5-3-5.I have a hotpoint ice diamond model rfa51p and alo - hotpoint-ice-diamond-model-rfa51p-alot-iizpua1124tc1voeqjalmrl5-3-9.jpgds/images/hotpoint-ice-diamond-model-rfa51p-alot-iizpua1124tc1voeqjalmrl5-3-9.jpg
Posted on May 07, 2015
SOURCE: red and green light on
your filter needs to be changed when it is red
Posted on Apr 17, 2008
  • 159 Answers
SOURCE: hotpoint iced diamond fridge just stopped working
firstly change the thermostat
Posted on May 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: hot motor
Replace the start relay and overload. Sea Breeze
Posted on Aug 27, 2009
  • 30 Answers
SOURCE: Fridge Icing Up
Sounds like you have a defrost Prob. Take back cover off. Turn defrost timer in to defrost mode you will feel a click. timer may be located in fridge. ceiling or back wall if not there check bottom of fridge. behind kick plate or in back bottom of fridge. by compressor. See if heating element gets hot if not check for 120 volts at heater and defrost thermostat ( Terminator ) if not check defrost timer if you do have 120 volts check for 120 volts at heater terminals if no voltage or weak voltage replace terminator if you do have good voltage replace heating element. When ice builds up the fridge. starts to get warm turn off for 24hrs turn back on fridge. will run OK till ice builds back up.
Posted on May 22, 2010
SOURCE: fridge keeps freezing
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
Posted on Sep 13, 2010
My mumjust cleaned out her hotpoint rfa52 iced diamond fridgefreezer&pluged it bk in (full working order be4 clean) &now it doesn't work. Would love here that it doesn't have 2go 2 the dump ??
Check the wall socket, the breaker and the thermostat control inside the machine. Also check if you can hear the compressor working at the back.
My mum just cleaned out her Hotpoint RFA52 Ice Diamond fridge-freezer and plugged it back in. It was in full working order before the clean and now it doesn't work. Would love hear that it doesn't have to go to the dump.
Jun 17, 2016 | Hotpoint Refrigerators
I have a hotpoint ice diamond rfa51p and alot of water fills the fridge what causes this?
Apr 20, 2015 | Hotpoint Refrigerators
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
How do i defrost freezer on Hotpoint RFA51p fridge/freezer? Its way too cold and totally iced up.
switch it off,and leave the door open(24hrs),with towels to mop up water.wash out with clorine bleach and dry
before switching back on.clean all pipes/vents/drip trays ,then check door seals are tight all round and load up as usual after freezer reaches operating temp.DO NOT USE HOT WATER/STEAM TO DEFROST..
Jun 03, 2010 | Refrigerators
Operating instruction for iced diamond rfa 51p
high temp light on and not cooling in either freezer or fridge RFA51P ?
Mar 14, 2010 | Hotpoint Refrigerators
Water collecting in fridge well
your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Feb 02, 2010 | Hotpoint Freezers
Fridge makes a clicking sound, stops if lever for ice/water press
this model has a p c control in the back and the clicking sound is common when its failing . Pt # wr55x10656 ) there is a up date kit for this frig . ck on the kit before replacing the board as its included in the kit . hope this helped ****
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
No model number on fridge
Open the door, crouch down, then look up - it's under the top on the left
Oct 18, 2009 | Refrigerators
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
108 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
