Question about Hotpoint Refrigerators
I have a hotpoint ice diamond rfa51p and alot of water fills the fridge what causes this?
  • Hotpoint Master
  • 5,323 Answers
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Posted on Apr 21, 2015
Ice maker not filling door not dispensing water
Make sure the temps in the fridge aren't cold enough to freeze the filter... Water valves rarely fail at both solenoids at the same time, so be sure the water supply is turned on and that the water line is not kinked (bent in half) behind the machine... Hotpoint Refrigerator Water Filter MWFP , Hotpoint Refrigerator Water Inlet Valve WR57X10032
Aug 02, 2016 | Hotpoint HSS25GFP Side by Side...
My mumjust cleaned out her hotpoint rfa52 iced diamond fridgefreezer&pluged it bk in (full working order be4 clean) &now it doesn't work. Would love here that it doesn't have 2go 2 the dump ??
Check the wall socket, the breaker and the thermostat control inside the machine. Also check if you can hear the compressor working at the back.
My mum just cleaned out her Hotpoint RFA52 Ice Diamond fridge-freezer and plugged it back in. It was in full working order before the clean and now it doesn't work. Would love hear that it doesn't have to go to the dump.
Jun 17, 2016 | Hotpoint Refrigerators
I have a hotpoint ice diamond model rfa51p and alot pf water is on the fridge what would this to happen
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
God is so good: so this is why I give free advice so please thank him not me.
Apr 20, 2015 | Hotpoint Refrigerators
Our Hotpoint Ice Diamond fridge/ freezer has developed a slow leak, or rather, it collects water condensate on its floor in the upper compartment which then oozes out onto the floor. I don't have a...
Thier are 2 possible thing causing that leak.
1 ) a blocked defrost drain..this tip i wrote will tell ya how to clear the defrost drain
FREEZER ON THE TOP OR BOTTOM http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
SIDE BY SIDE http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
2) the water inlet valve that distributes water to icemaker and in door dispenser (if equipped) hasa pinhole in it and spraying water onto the floor...to check that gotta pull out ref.from the wall and remove lower rear service plate and inspect the valve for a pinhole
GENE
Aug 31, 2011 | Hotpoint Refrigerators
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
How do i defrost freezer on Hotpoint RFA51p fridge/freezer? Its way too cold and totally iced up.
switch it off,and leave the door open(24hrs),with towels to mop up water.wash out with clorine bleach and dry
before switching back on.clean all pipes/vents/drip trays ,then check door seals are tight all round and load up as usual after freezer reaches operating temp.DO NOT USE HOT WATER/STEAM TO DEFROST..
Jun 03, 2010 | Refrigerators
Operating instruction for iced diamond rfa 51p
high temp light on and not cooling in either freezer or fridge RFA51P ?
Mar 14, 2010 | Hotpoint Refrigerators
Water collecting in fridge well
your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Feb 02, 2010 | Hotpoint Freezers
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Oct 16, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
122 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
