Question about Jenn-Air Kitchen Ranges
I have a Jenn Air range model JES9750BAW and now continuously beeps while the word 'clock' flashes. Have unplugged for hours and plugged back in and still beeps all the time. Help!! So annoying...
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Its asking you to set the clock, set the clock and it will stop
Posted on Apr 21, 2015
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Posted on Oct 23, 2008
  • 5 Answers
SOURCE: Jenn air range model SCE30600B error code FC
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Posted on Aug 31, 2009
localwonder
  • 6784 Answers
SOURCE: Magic Chef Electric Range F1 code won't stop
Hi. this is referring to a Defective touch pad or clock (ERC). This will need to be corrected. Normally, you will need to, simply, replace the main control Board(ERC).
Follow this testing procedure to confirm the damage.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 25, 2009
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
F1 flashes even after changing control panel
F1 touch pad / ERC test This simple test will help determine
(Clock).
Dec 27, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Replaced desplay board and nothing worked replaced right and left relay boards and clock works nothing else flashes f1 f1 checked wiring harnness with ohm meter ok dont know what else to try
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Dec 27, 2010 | Jenn-Air Electric Double Oven
Jenn air oven door locked after getting an F1 message after the self cleaning was done..help i cant unlock it
(Clock).
Dec 10, 2010 | Jenn-Air JJW8530C Expressions Collection...
Built in Jenn Air oven just gave a fault code of F1
Nov 22, 2010 | Jenn-Air JJW8230D Electric Double Oven
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
F 1 code after using Jenn-Aire electric oven
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem.This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Sep 21, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
F1 code problem
Jul 28, 2009 | Jenn-Air JGW8130A Electric Single Oven
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
94 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
