Re: I have set of 22"in rims that came off a 2013-14...
Probably not-- you will have to see if there are the same number of stud holes, the same daimeter studs, the correct length of the studs, the same pitch circle diameter of the studs and the off set of the centre is the same
Almost all, then you'll need to go over to Scosche.com and select a 'in-dash installation kit' . They provide a dash mounting panel for you to side the new radio's mounting sleeve.
Place the transfer case in low range. Pry the shift indicator bezel out of the console using a trim stick.
Apply the parking brake and place the transfer case in neutral. Remove the parking brake trim insert. Remove the console attaching screws. Lift the console up and disconnect the 4WD indicator lamp hamess. Remove the console.
Remove the passenger side knee blocker. Remove the single end screw. Remove the screws below the glove box. Remove the screw at the courtesy lamp. Remove the ash receiver and the screws behind it. Remove the instrument panel armature screw behind the ash receiver. Open the glove box and remove the screws behind it. Lower the panel and disconnect the lamp harnesses. For additional instrument panel service procedures to complete steps 6 thru 25, refer to Instrument Panel, Gauges and Warning Indicators/ Instrument Cluster / Carrier/ Service and Repair/ Procedures. See: Instrument Panel, Gauges and Warning Indicators\Instrument Cluster / Carrier\Service and Repair
Remove the pod switch bezels on both sides of the steering column with a trim stick.
Remove the drive side knee blocker. Remove the end screw and screws located at the bottom of the knee blocker.
Remove the cowl top trim panel by prying it up with a trim stick. Remove the solar sensor if equipped.
Remove the "A" post trim panels.
Remove the remove the bolts that attach the lower instrument panel reinforcement to the instrument panel armature and remove the reinforcement.
Disconnect the park lamp switch.
Pull back the carpet at the transmission tunnel from the base of the instrument panel center bezel. Remove the nuts from the upper studs and bolts through the floor that secure the instrument panel center bracket.
Remove the bolts that secure the instrument panel center bracket to the drivers side of the transmission tunnel.
Remove the screws securing the Vehicle Information Center and remove it. Remove the screw fastening the mounting bracket.
Unplug the vacuum harness connector or vent tube on ATC equipped vehicles and the wire harness located under the passenger side of the instrument panel.
Remove the screws holding the passenger side kick panel, along with the screw from the kick panel shroud.
Unplug the antenna cable near the right cowl side panel.
Unplug the instrument panel wire harness connectors from the junction block at the right cowl side panel.
Remove the bolts that secure the instrument panel armature to the windshield fence.
Remove the nuts that secure the top if the instrument panel armature to the windshield fence.
Remove the bolts that secure the ends of the instrument panel to the cowl side panel.
Remove the nuts that secure the steering column to the brake pedal support and lower the steering column.
Remove the bolts that secure the instrument panel armature to the brake pedal support.
Place a protective cover on the seats. Lift the instrument panel off the windshield fence studs and maneuver the instrument panel out and lower it onto the seats.
Disconnect the refrigerant lines from the evaporator tubes. Make sure to install plugs or tape the ends of the lines and fittings to ensure that excessive amounts of moisture do not contaminate the A/C system.
Remove the vacuum line at the tee from the main vacuum supply harness. This line runs through the body with the upper refrigerant line.
Remove the Powertrain Control Module with connectors intact and set aside.
Remove the heater A/C housing mounting nuts from the studs on the engine compartment side of the dash.
Remove the heater A/C housing from the vehicle.
To Install the components, reverse the procedure stated above. Torque Specifications: Instrument panel center bracket to floor transmission tunnel fastener: 28 Nm (250 in. lbs.) Instrument panel to windshield fence bolts and nuts: 12 Nm (105 in. lbs.) Instrument panel to cowl side inner panel bolts: 12 Nm (105 in. lbs.) Instrument panel to steering column support bolts: 12 Nm (105 in. lbs.)
Every morning at lunch time and evening my jeep won't start. It doesn't grind but the electrical goes crazy. After a couple of trys it finally starts. Help
The light tells you that there is a stored fault code. You can have the codes read for free at most of the larger parts outlets. That will tell you which system need attention. A decent manual like chiltons will also be helpful in tracking down the exact nature of the problem as well.
Anything fits if you increase ride height accordingly. As long as it clears the brakes it should only affect how far the front wheels will turn before rubbing the wheel wells.
The limited edition brings memory setting for mirrors and seats, it recognizes which key are you putting in the ignition and puts the saved setting accordingly to that driver's key. That is the reason your seat keeps moving. You need to reprogram the seat position for that key. Good luck
