Question about Refrigerators
The wire with the plug came out, I dont know which wire goes where - and I dont want to blow the compressor. Does anyone have diagrams?
  • Refrigerators Master
  • 5,323 Answers
IF U HAVE THE SCHEMATIC U CAN FOLLOW AND TRACE THE WIRING U HAVE THE GROUND OR COMMON THE THE START AND RUN WINDINGS, THE RUN WIRE i BELIEVE IS RED THE START IS WHITE SEE PIC
The wire with the plug came out, I dont know which - wire-plug-came-out-dont-know-wire-goes-kvax0h5nolktkyinzrohy2he-2-0.jpg
Posted on May 20, 2015
I need the wiring diagram for a Nordyne GS3BA-024KA condenser
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
Apr 22, 2017 | Heating & Cooling
I have a refrigerator rs25h5111sr but i dont have the plug that goes to the compressor i meed to know how can i do it?
That refrigerator has a inverter control board and compressor so not just any plug to plug up to that compressor it calls for this part number for that plug assembly DA39-00154B Refrigerator Compressor Wire Harness Part Number DA39 00154B GUARANTEED...
Jan 16, 2016 | Refrigerators
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
My left turn signal no longer works on my '00 T&C. Hazards, brakes and right turn signal works. I've replaced both lights in front and back, replace turn signal switch and check fuses'. What else can I...
SOUND LIKE WIRE PROBLEM.YOU NEED A WIRE DIAGRAM TO CHECK THE TURN SIGNAL SWITCH WIRING DONT PLUG A WIRE IF YOU DONT KNOW WHERE IT GOES COULD CAUSE ELECTRICAL BLOW OUT.TRY TO GO ON LINE LOOK FOR AUTODATA DIY COM LOOK FOR ELECTRICAL DIAGRAM.
Nov 18, 2010 | 2000 Chrysler Town & Country
Loose wire on ac compressor
Here is a picture of one --
http://www.a-aironline.com/detail.aspx?ID=221
You can see wehre the wire goes in..
Good luck !!
Please dont forget to rate ;o)
Aug 14, 2009 | 2000 Kia Sportage
A/C compressor blows hot air
If the fuse is the problem it's located under the hood near the relay inside the rely box but I think you have a problem with the blend door not the fuse, if the compressor is turning and the fan is blowing then it also most certainly be a vacuum motor not functioning.
Jun 18, 2009 | 2000 Ford Mustang
Has anyone fixed this problem
wonder why it doesn't blow a fuse? follow the wires that get hot all the way back to power and ground yes wiring diagram would help you say clutch doesn't kick on or off, it pretty much has to be engaged or disengaged, prolly engaged if wires getting hot. if a/c blows cold, it's engaged.try unplugging compressor or removing belt or both and see if vehicle operates ok without it, then you know where to start
May 23, 2009 | 1990 Cadillac Brougham
Wiring diagram
send me an email at b4829@yahoo.com and ill send you a diargram dont forget my four boxes
Jan 19, 2008 | Frigidaire GLER341A Electric Dryer
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
