Question about Singer Quantum XL-1000 Computerized Sewing Machine
Why doesn't the machine pick up the bobbin?
I used a thick fuzzy piece of material and now it makes a clicking noise. The bobbin and case moves, however will not pick if up. I did break the needle and replaced it.
  • Singer Master
  • 638 Answers
Keep the bobbin area clean.
Now, what caused the needle to break? With the clicking noise it sounds like your timing is off.
1. Check this: With the bobbin and bobbin case out.
2. Now: Move the hand wheel and watch the needle under the plate.
3. As the needle starts to rise (still under plate) watch the needle and the hook (pointed thing under the bobbin case). The needle and hook should come close but not crash. Try the needle on the left and the right.
4. If they ever touch this means it is needing to be timed at your local shop.
Posted on Apr 20, 2015
  • 5 Answers
You may have fuzz in your bobbin case or under the plate. If you have canned air, spray it out. Are you using a pre-wound bobbin or one you wound yourself. I've found pre-wounds to be the best. Make sure your thread is pulled thru the bobbin case correctly and your needle up top is threaded correctly too. It's real easy to miss either one. Also, be sure to use a good backing when using fuzzy fabric. What size needle are you using. Too small of a needle may cause this also. For standard embroidery or sewing usually use an 11. Hope maybe this will help. Kindest regards,
Jody
Needle not picking up bobbin thread and it makes funny loud noise
Sometimes both symptoms are a result of a bent, dull, or damaged needle. Try installing a brand new needle.
If it is still not picking up the bobbin thread and making a noise, take it for service. It most likely has a needle/hook timing issue and the noise could be the needle making contact with the needleplate or in the bobbin area. Continued use could cause the needle to break and flying pieces of needle, in most cases, are not a good thing.
Jun 18, 2016 | Brother Sewing Machines
What #holes on 158.1786181 solid state Kenmore sew machine bobbin
Do you mean the lower bobbin spool? It should not matter too much so long as it fits. Try it on a scrap of material and see how it goes.
Mar 02, 2015 | Kenmore Sewing Machines
My brother Disney sewing and embroidery se- 270d makes load noise and stopes tangles thread and material
I was just telling someone else that I recently learned from the sewing goddesses that be (at my local Hancock's Fabric Store)--that--you have to use the right bobbin. I mean plastic if your machine came with plastic. Class 65/ 55 (I think those are the numbers) as to match the machine's design. Use metal if your machine came with metal.
the bobbin case is weighted "just so" in order to be sure to run smoothly with the particular bobbin type.
Of course, the top tension and bottom tensions must be checked as well.
You could have some stuff stuck in the bobbin encasing thingy (it has two black tapered lever arms that you can move about 15 degrees to the outside and the case encasement pops out).
Mar 03, 2014 | Brother Sewing Machines
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
Bobbin case is moving and making noise
then the bobbin case may need to be replaced, you can either take the machine
to a sewing machine shop to have it checked to see what wrong with the machine
& make sure it's the bobbin case or buy a new bobbin case & see if that solves
the problem & if it doesn't then you'd still have to take it in to be checked
Apr 27, 2012 | Brother XL-2600I
Using jeans thread, bobbins thread pulls out immediately, tension is incorrect
Sometimes you need to go for a lesser tension as soon as you move up in thread thickness. A jeans thread is often nylon and already has tension in the way it's wrapped. Try using a low tension and a straight line seam (don't use a zigzag pattern or wave).
Also, try practicing on a piece of scrap material first- make sure it is the same thickness/consistency as the jean material you want to work on. Do a few forward and then backward lines; this will make sure the problem isn't in the initial wind of the bobbin itself, and this usually gets the extra slack out of the bobbin.
Mar 13, 2011 | Singer 1507
On sewing a normal seam, the bottom piece of material becomes puckered
From what you describe, it sounds like you have your bobbin tension a bit too tight. Take the bobbin case out of the machine and hold it up by the thread. The bobbin case should move down slightly when you give it a slight ****. If the bobbin case doesn't move much it is too tight and if the bobbin case falls into your hand it's too loose.
Nov 13, 2009 | Bernina Virtuosa 160
Singer Quantum XL-1000 Computerized Sewing Machine Logo
117 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
