Question about Acer Aspire X1200 Desktop PC - Athlon X2 Dual Core 2.5GHz, 4GB DDR2, 320GB, DVDRW, V ...
My network card is faulty pc not 12 months old
  • Acer Master
  • 4,134 Answers
When you say faulty, I assume you mean that it is failing to connect to your router or modem. First, have you checked to ensure that the driver for the network card is not missing or corrupt? This can occur. Second, have you checked to ensure that you have not lost the security password (WPA/WEP) for the network card. This can prevent connections. If you are absolutely sure that the on-board network module is defective (it can happen...power surges and the like), then you can either get warranty service (if it is in warranty), or you can purchase either a USB adapter-type network card, or one that you can install internally to replace the faulty one on the mainboard. You don't necessarily need to do this, but you should go into the CMOS setup and disable the on-board network module if you don't plan to use it any longer. It will help to avoid confusion and will free up some mainboard resources.
Posted on Apr 20, 2015
Brand new when i tap screen nothing comes up
Faulty touchpad, if its brand new swap it from purchase location as it will have a 12 month warranty. If its over 12 months old then get the pad replaced.
Mar 27, 2014 | Tomtom Start 50M 5" GPS with Lifetime Map...
I put my sony lt18i on charge overnight but it's showing 7hrs of charge at 100%. After restarting it shows 23s. It's only 6 months old!!!
You most likely have a faulty battery. I suggest you go to the shop where you purchased the laptop and get a replacement battery at no cost to you as the laptop would be still under the 12 months warranty period.
Oct 10, 2012 | Sony Computers & Internet
Cannot formate 4GB memory to FAT16 use for mobile phone samsung
If you are trying to format this card through a PC don't bother, it will not work when you install it into the phone.
If you are trying to format this card in the phone, you may find that your phone will not access high capacity type cards as few older phones do, and by older, I mean if the phone is more then 6 months old, the chances are that it will not allow access to the card.
Some phones also have an upper limit to the size of the card they will address and most will not address any card larger then 2gig..
Of course, you may also have a faulty card, even from new, some of the high density cards are faulty..
If you can get access to a smaller card (like say a 1gig), try that in your phone. If it works then you will find that your phone cannot address high density cards.
I have a camera, less then 6 months old, will address normal 2gig cards but it will not allow high density 4 gig cards which is a pain but alas, nothing you can do about it..
Dec 05, 2010 | SanDisk 4GB microSD High Capacity Memory...
Hi, I have a Sony Ericsson W508 phone, I had just sent a text when I noticed it said "Incorrect SIM card", I took the back off the ph, removed battery & SIM card, replaced them (correctly) & now my...
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.onlinegsmunlock.com/sony-ericsson-w508/rs7wp9/
Aug 27, 2010 | Sony Ericsson w580i Cellular Phone
DIR-615 , power led blinks always, wifi and internet not working
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
5. check the power adapter it may be faulty.
Apr 28, 2010 | D-Link DIR-615 Wireless Router
Trying to use an orange sim card but phone locked dont know the codes
You will either need to unlock locally (which will invalidate warranty if less than 12 months old) or Speak to your network provider to get the unlock code off them for which there is normally a fee of around £15
Oct 07, 2009 | Motorola Mobility W220 Cellular Phone
Monitor goes to sleep no input signal only 1 mo old
Normaly the monitor is not picking up the signal from the PC, it could be VGA cord is not connected, faulty, or the video card is faulty,or the monitor is not compatible to the PC. It could be one of my suggestions. Trouble shoot by connecting your monitor to another working PC and see what happens.If not the VGA cord is faulty and not picking up signal from the PC. Hope it helps.
Jan 21, 2009 | Computers & Internet
Monitor problems
It is possibly your video card that is having the fits. Try replacing your video card or have your CPU checked... It is not a problem with the monitor, rather a problem with the computer...
Mar 10, 2008 | Computers & Internet
Wirless network card
well i think obviously the network card is damaged and causing the pc to stop when checking the pci slot that the card is in. Return to the supplier as the card should light up orange or green when operating normally, and under warranty if Os has a 12 month warranty period. Assuming you haven't had a power surge, they should replace the card.
Sep 24, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
Acer Aspire X1200 Desktop PC  - Athlon X2 Dual Core 2.5GHz, 4GB DDR2, 320GB, DVDRW, V ... Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
