Question about Kenwood Car Audio & Video
How do i do the setting of kenwood split e sense 1.5 ton?
Its not chilling and i dont know how to set the mode
SOURCE: how do i set the distributor timing?
Hi stevens-jr,
Make sure that the crank shaft and the cam are both on their respective timing marks....Retention the chain....Once you've done that, check again to make sure that they are still synchronised....If your dealing with coil ignition it's fixed and will be automatically set once the valve timing is set....Any minor adjustments must be made electronically.... If you have a distributor, follow below:-
Once you're sure of the valve timing, set the engine to TDC with number one piston, on the ignition or power stroke... (inlet and exhaust valves both closed) and fit the distributor, so that the rotor is facing the place on distributor where number one plug is situated on the cap....If need be, fit the cap to see the relative position of number one plug....That should give you the relative firing point....Set the distributor by turning it, so that the edge is just stepped away from the pick up coil....the spark takes place as the rotor moves away and breaks the magnetic field between the two....This should happen at about eight degrees before TDC....Once the engine has started, set it with a strobe light...
Best of luck
Regards Johngee10
Posted on Aug 31, 2008
SOURCE: Whirlpool Mastermind chrome 1 ton split ac, newly
how to use blower
Posted on Jan 11, 2011
icemelts
  • 246 Answers
SOURCE: i have a coleman 3
Normally, the tag on the outside unit (as far as amount of refrigerant) takes into account the line set and the evaporator coil.
Posted on Jun 10, 2011
  • 9 Answers
SOURCE: I need to know the correct high/low freon setting
you can mixmatch a split system if tonnage is the same.1ton,1ton,2ton,2ton etc..
Posted on Jan 14, 2012
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Car ac cooling problem
It might just need to be recharged or the inline filter could be plugged
Apr 06, 2014 | Cars & Trucks
Where do i turn off the offline mode
Offline Mode maybe located in Profile Settings. Try getting into Profile Settings and then choose any other Profile. It may ask you to confirm whether to exit Offline Mode/Profile, to which you'll have to say OK or YES, whatever is there as an Option.
Mar 29, 2014 | LG Cell Phones
How to change de time
push the SET/LIGHT and LAP/RESET button simultaneously.. push MODE button to go to time setting option.........chill
Feb 11, 2012 | Adidas Digital Chronograph Black Strap...
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Our split system is not blowing cool air all the time? Can you tell me what the problem might be. Thanks
To get proper cool, keep cool mode. Temp setting minimum 3 degree less than room temp.Check indoor coil,air filter and blower wheel are cleaned.
Check gas pressure is good by keeping your hand on suction pipe (bigger size) which gives chillness.
Hope, helpful.
Jan 28, 2011 | Samsung Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
Car Audio & Video Logo
63 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
