Question about Electrical Supplies
My generator does not supply power I have checked there is no current from the generator housing I have also checked the power diode and they are fine
  • 1,169 Answers
Try flashing the rotor field. It may have lost its magnetism. Most standby generators will lose this if in long term storage.
If you don't know to do this have someone that does as you can damage your generator's alternator if done incorrectly.
Posted on Apr 20, 2015
Start em650z
Capacitors typically fail due to overloading and large current inrushes like HVAC motors compressors etc. Or shorted wiring / windings. Diode? Are you referring to diodes in the exciter? Often fail due to over current
Nov 23, 2013 | Honda Generator 10 Circuit Transfer Switch...
No voltage output l88 diodes check good
putting out some voltage is a good sign i think you need to look at the voltage reulator
Aug 16, 2012 | Electrical Supplies
Will not produce current
try a full load on it
if still no luck could be the avr if it has one if not diodes on the armature
Feb 26, 2010 | Coleman Powermate Premium Plus 6250W...
MAIN INPUT FUSE KEEPS BLOWING
theres a shortage in the circuit try check the rectifier diodes at primary power supply section, not dangerous to little knowledge,refer to a qualified service technician
Jan 03, 2010 | Samsung TXP3275H 32" TV
My generator runs but does not prouduce electricity
The basic cause is the rotating magnetic field has collapsed.
Causes of that can include blown rotating diodes, blown regulating capacitor, loss of magnetic remanence.
Search google for things to try. IF it is only loss of the small bit required magnetism, SOME have found plugging in an electric drill that DOES NOT have a throtle speed control and spining the drill with it switched on will create enough field to start the unit generating. Blown diodes or capacitor requires replacement of parts.
If the unit is a permanent magnet type (usually only small units) then there would be open circuit in the wiring or the rotor has somehow lost the magnetism.
SOME units have brushes to excite the field with a direct current. Loss of brush contact to the slip rings or the rectifier supplying the current will cause no output of the generator.
In your case, the Dewalt DG6000 is a brushless type. The most probable cause for the problem is the regulating capacitor. IF the unit has been overloaded or a short placed on it, then the rotating diode(s) have probably been shorted. Searching google you will find that there is a method using light bulbs in series from utility pwer to attempt recharging the rotor. This will ONLY work if the parts have not been damaged.
Oct 26, 2009 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Timer
firstly check your sleeping timer set ups. if that is okey, then check the following
the power supply components eg
power transistor on the power supply lekage
zener diodes, power diodes of the bridge rectifier.
in short the supply is drowing to much current, hence semiconductors are heating up and reach a cutoff point, and saturates
Mar 29, 2009 | Toshiba 35A44 35" TV
Microwave does not heat
The high voltage circuit that supplies power to the magnetron may be separately fused inside. Unplug it, remove the back panel and look for a fuse clip. The high current fuses (20-30 amps) often have a white ceramic housing and are tubular. If you have a multimeter at home (you should, they are cheap) you can check the fuse after removing it from the holder.
The reason your other things are still working is that they have separate supplies; the one for the panel will supply only low voltages and not much current.
If you have a meter, check for a largish black plastic component often mounted on the floor of the case. This will be a diode or diode bridge and this can also fail.  A meter would let you check it if you have one.
Nov 28, 2008 | Whirlpool GH7145XF Microwave Oven
No power output
Hi, check your exciter cap inside the control box as it probably is knackered, Replace it with a new one.
Or if the unit was severly overloaded the windings are probably fried.
Oct 21, 2008 | Briggs Stratton H7159 & Stratton® 5500,...
Electrical Supplies Logo
37 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
