I have a Blanco Dishwasher - on all cycles it cuts the power or shorts-out! does any one know why this is happening?
Requires a reset of the power board or mains to continue the program cycle. Cuts out at 10mins in and 20 or so mins from finishing. Any thoughts?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check heater elememt for a leak to earth
Posted on Apr 20, 2015
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Why would my blanco dishwasher keeps power cycling?
Hi Scott, yes is the short answer. most electronics today have a set current for operating motors usually for under load conditions worst case. If there was a blockage or filter restricting the flow the motor will pull more current which will be detected by the motor circuit.
If this were not the case the power to any motor would be unlimited and would simply burn the motor out. Check the sump or pump and the drain filter. Tim
Aug 22, 2014 | Dishwashers
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
My blanco bfdw6x dishwasher has the folowing symptoms - power on, 30 min wash cycle set, after pressing start cycle button the machine sound likes it tries to start, but then cuts out and the digital...
Ours does the exact same thing. We pull it out and tip it which drains some water on the floor and then it works. It is something a technician told us ages ago, something to do with a water level switch underneath.....but its driving us mad. We have to do it on a regular basis. Does anyone know how this can be fixed more permanently. thanks.
Sep 03, 2010 | Dishwashers
Try unplugging it from the wall socket and leaving off for about 1 min then plug in and turn back on
Aug 14, 2009 | Dishwashers
Dishwasher is shorting out power supply when on hot cycle
The wash tank heater is likely the issue.Remove the 2 wires on the heater and tape them up and run a cycle,let me know.
Apr 27, 2009 | Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
