Question about Connex Radio Communications
What watt dead key and swing on CONNEX 3300 HP
  • 6 Answers
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
Posted on May 15, 2015
One Wire
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
Communicomm
  • 90 Answers
SOURCE: Cobra 142 GTL no dead key
Are you sure that you're on the AM mode? It sounds more like you're on LSB or USB. If you are on AM, the problem may be the power control (VR6) inside the radio.
Posted on Nov 12, 2008
  • 39 Answers
SOURCE: ONLY 2 WATTS DEAD KEY AFTER BEING PEEKED/TUNED AND MOD KIT.
Has anything changed with your antenna or your power supply ? The only real way to get an accurate reading is to check it with a dummy load and form a base line from there.Good Luck
Posted on May 23, 2009
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
SOURCE: Just need to know what are proper settings on my
The proper setting depend on what you are doing with the radio at the time.
Here is a link for the owner manual http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Posted on Oct 19, 2010
Connex 3300 HP ,tx light on,dead keys 45 - 50 watts ,no modulation
Check for a Bad, whats called the AM regulator on the back corner of chassis by pwr connector. 2sa or 2sb styles. 2sb817 if available is a good $3 replacement.
Nov 04, 2015 | Connex Radio Communications
No transmit signal
Does the unit work when it is not hooked up to the linear? The obvious choice is that you have blown finals in the RF output section of the radio.
Apr 02, 2014 | Connex 3300 240-Channels Base CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I need to tune my connex 3300 so I can run my linear.can someone send me directions on this...
you will need a good watt meter and dummy load. or any cb shop can do it for $8.. thats the normal charge here in texas. keep the wattage low, so you don't damage the amp. less than 5 watts max
Feb 13, 2011 | Connex 3300 240-Channels Base CB Radio
My connex 3300 wont transmit anymore and the talk back wont work either,i have tried a different mike and when you key it up the meter still won't swing.
Plug in an external speaker to the pa jack ... Switch the band selector to pa and see if you hear yourself... No? Bad audio chip
Dec 29, 2010 | Connex 3300 240-Channels Base CB Radio
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Jul 15, 2009 | Connex 3300 240-Channels Base CB Radio
No audio meter needle swings on another radio
is the radio working? sometimes the meter just dies that will not effect yor radio
May 30, 2009 | Connex 3300 240-Channels Base CB Radio
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Mar 07, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
518 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
