Question about Shop Vac Vacuums
Need supplier in dubai for shop vac vaccum machine
Shop Vac on/off switch
Yes, you need to remove head unit from canister and pull head unit apart, switches are usually common and are just push in. available from electronics suppliers
Mar 17, 2014 | Vacuums
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
My bissell bagless vac has no vaccum. ihave
You will have to clean the filter and clean the main motor.  I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
Mar 06, 2009 | Vacuums
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux lux vaccum cleaner hose and fitting/nozzle needed
Call your local Aerus/ Electrolux branch. If no luck with that try www.aeruspa.com
Hope this helps
Jan 09, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
