Question about JDM Toyota Corolla 93 94 95 96 97 1993-1997 AE100 Front Bumper Mesh Grill Grille
I changed the whole steering column and ignition switch but I didn't disconnect the neg from the battery and now everything that is turn on by t acc don't turn on what did i do wrong please help me
    Master:
  • 987 Answers
Most likely the switch is out of adjustment, either that or you may have a damaged wire or connector
Posted on Oct 08, 2015
I changed ignition switch on a tercel in fact I changed the whole steering column and everything with the acc don't turn on why
Is the plug the/ same on the back of the switch is the key worn out
tell kea little more what's different is the white back part of the
switch in all the way so the cyclometer turns within .
Apr 20, 2015 | 1995 Toyota Tercel
Wind shield wipers only work on high speed. no slow or intermitent .
This is usually a problem in the turn stalk. The usual fix is to replace the entire unit which is called the MFS for multi function switch.
The process for replacing this switch is to disconnect the NEG cable of the battery and turn the Ignition switch to RUN or ACC position. At the bottom of Ignition switch there is a spring loaded pin which is accessible from a hole in the plastic cover of the steering column. Use a drill bit or small pin to press on the spring loaded pin in the Ignition switch.
When you pull up with the Ignition key, the lock cylinder should slide out. This is necessary to remove the chrome Ignition key flange to allow the column cover to slide apart. There are about 4 additional screws holding the column cover together. You will have to move the tilt in the column back and forth to wiggle the column cover free.
The MFS is secured with 2 screws with recessed Torx heads. There are several connectors with delicate clips to unfasten. You change out the old for new parts and then reinstall by reversing the above instructions.
I hope my solution is very helpful to you. The MFS part runs $85 to $160 depending on the supplier. With the changing of this switch you will also gain new components for your turn signals contained within the unit.
May 17, 2011 | 2004 Ford Expedition
Have 1996 marquis have to get ignition out to get top cover off how do i get ignition out
Hello, The steering column cover has several access holes on the bottom of the plastic. There are 4 screws in the cover and they are phillips head. There is one hole in the cover bottom to access a spring loaded pin on the ignition.
You need to disconnect the NEG cable of the battery. Then turn the key to the ACC or RUN position (depends on model) to line up the parts inside the switch. The cover on the column will need to be removed if you want to remove the entire switch and not just the locking core. You will know when you push a drillbit or nail into the spring pin release hole under the Keyswitch.
You should be able to use your keys to pull the cylinder right out of the lock if its in the RUN or ACC position. There are usually 2 special screws holding the Ignition switch to the column. These are theft-resistant shaped screws and the screwdriver or screwbit is available at an Autoparts store.
Take a screwdriver or sharp object and scribe a mark on the steering column where the ignition switch is positioned so you can duplicate the position. Change out the switch and then temporarily install the lock core and temporarily connect the battery. Start the car, move the gearshift, if everything is in alignment; everything will work. If something does not work you may have to adjust the ignition switch beyond the scribe marks until it does work. Then position the ignition switch tightly.
Remove the battery cable once more, pull the ignition core and reassemble the plastic and drop the lock core into position. Once everything is together, reconnect the battery and it should be like new.
Apr 25, 2011 | 1996 Mercury Grand Marquis
99 ford expedition put car in gear and the radio and wipers cut out
Hello, I'll take a shot at solving this one. It would either be a chaffed wire in the steering column or a bad Interlock switch under the dash by the pedal levers. Check wire connectors for corrosion on either end of the steering column. Check the Interlock first.
To remove the plastic cover on the Column you will need to pull the Ignition lock. You will need to disconnect the NEG battery cable and have the Key turned to either ACC. or RUN position to remove the cylinder after pressing the spring lock under the Ignition switch. There is a hole under the keyswitch to put a punch and press upwards to release the lock cylinder. This is necessary to remove because of the flare on the cylinder core preventing the plastic cover from clearing the lock.
You will need to tilt the steering wheel to remove the plastic cover. Then reconnect the Battery and test the circuits. Would like to know what you finally find as the problem to add to my bag of tricks.
I hope my solution is very helpful in fixing your Expedition.
Apr 03, 2011 | 1999 Ford Expedition
How do I replace the ignition switch were is it located
you will find clear pictures here;
http://www.stolenandrecovered.com/index.php
Ignition Switch & Lock Cylinder
  • REMOVAL & INSTALLATION
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
  3. Remove or disconnect the following:
    Steering column upper and lower covers Key ring antenna Steering lock cylinder
  4. Insert the key in the steering lock cylinder and turn it to the "ACC" position.
  5. Using a small Phillips head screwdriver, pull the steering lock cylinder toward you.
To install:
  1. Install or connect the following:
    Ignition switch to steering column Steering lock cylinder to ignition switch Key ring antenna to ignition switch Steering column upper and lower covers
Jan 15, 2011 | 1999 Plymouth Breeze
I need to remove the ignition barrel to replace it how is this done
IGNITION LOCK CYLINDER AND SWITCH
Removal Procedure
  1. Disconnect the negative battery cable
  2. Remove the lower steering column cover panel by removing the screws.
  3. Disconnect the electrical connector for the immobilizer detection coil, if equipped.
  4. With the key in the ignition turned to the position designated ACC, remove the lock cylinder by pressing down the detent spring with a 2.5 mm alien wrench or other suitable tool, and pulling the lock cylinder out of the switch cylinder housing. 5. Install the lower steering column cover panel with the screws. Tighten the lower steering column cover panel screws to 3 Nm (27 inch lbs.).
  5. Connect the negative battery cable
Jul 16, 2010 | 2000 Daewoo Nubira
How hard is it to change the Ignition Key Lock Cylinder? Do I need to take off the Steering wheel or does the guts just come out from the Steering Col with a pin, or something?
this is the oldest info I have. should be similar
Section 11-05: Steering Column Switches 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Removal
  1. Disconnect battery ground cable. Remove the upper steering column shroud by removing the four or five self-tapping screws. Remove tilt steering column lock lever (if so equipped).
  1. Remove lower steering column shroud.
  1. Disconnect the ignition switch electrical connector.
  1. Rotate ignition switch lock cylinder to the RUN position.
  1. Remove the two screws retaining ignition switch.
  1. Disengage the ignition switch from the actuator.
Installation
NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
  1. Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Check to ensure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install upper steering column shroud.
  1. Install the lower steering column shroud and tilt steering column lock lever (if so equipped).
Nov 06, 2009 | 1992 Lincoln Town Car
New starter but car wont start
funny...you have just told me what is wrong with it!!!
check power in, power out at the ignition switch...likely it has failed. switch is on the top of the steering column under the dash and is sometimes easier to reach if you disconnect the column from the dash and permit the sterering wheel to rest on the seat.
Apr 16, 2009 | 2004 Oldsmobile Alero
Need to change ignition lock cylinders
Fig. 7 Steering column & ignition switch assembly. Exc. 1984 Corolla 41767877
  2. Remove steering wheel, if necessary, steering column garnish, if equipped, upper and lower covers, Fig. 7. On Starlet models, remove upper cover.
  3. Disconnect electrical connectors from ignition switch.
  4. Turn ignition key to ACC position and remove ignition key cylinder.
  5. Remove screw and ignition switch.
  6. Reverse procedure to install.
Mar 23, 2009 | 1986 Toyota Pickup 4WD
JDM Toyota Corolla 93 94 95 96 97 1993-1997 AE100 Front Bumper Mesh Grill Grille Logo
Top Aftermarket Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Aftermarket Vehicle Part and Accessory Expert? Answer questions, earn points and help others
