SOURCE: frig freezer bosch kgv3120gb/01 with the
Hello button7
Welcome,
How old is your unit?
In today's refrigerator / freezers they share the air in a circulation process.
Or you may have this problem
Low
refrigerant change
If the unit has a low
refrigerant change, the freezer will not reach proper temperatures.
This must be checked by a qualified technician due to EPA regulations.
Let me know how you do!
Thank You for using our site,
Huuum
Please remember to leave a rating!
SOURCE: Our caravan fridge electrolux rm4206
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
SOURCE: Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
SOURCE: Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
