Question about Water Water Heaters
Our Infinity system heating, I can hear the ignition going (or trying), the fan/motor going but there is no water heating or that 'noise' you normally hear when it is heating. Thanks Chris
Inducer motor noise
Replace the motor.
Jun 29, 2017 | Water Heaters
Inducer motor noise
Never trust anything that comes to you new because usually they are made in china and are not consistent, but next time make sure clean air is being supplied if impeller gets dirt build it becomes imbalanced and will draw high amps and create that vibration noise. Also vibration noise can be caused by improper combustion set up.
May 15, 2017 | Water Heaters
Wirred into system gas valve will not open
Possibility solenoid valve is not working u shud hear a click when it opens
Oct 05, 2013 | Honeywell ST9120U1011 Fan Timer Universal,...
I have a John wood GSW water heater, JW317RF that will not come out of "lockout mode". I have reset the water heater numerous times and it will seem like its going to run but never ignites. I have bled it...
id say the draft u feel is normal (if it wasn't fumes wouldn't exit the home) lock outs usually occur when there is a fault to exist in the burner circuit (detected) like the flame proving sensor being defective(very common) or no draft fan running , you ill need to do a little more looking to determine what is needed
May 28, 2017 | Water Heaters
Fan makes noise
check to make sure fan blade is tight on motor shaft.KILL POWER TO UNIT FIRST
Sep 10, 2012 | Water Heaters
My rinnai infinity 16 is not heating the water. We have checked the powerpoint it is connected to and there is no problems with that. There is also gas to our stove, oven and ducted heating, so it...
There may be gas pressure at the valve but the valve, igniter, and/or thermocouple could be defective. Also, even with good ignition, the burner itself could be defective.
Dec 23, 2017 | Water Heaters
Why does my water heater make crackling noises
The crackling noise is from build-up of sediment.
I forget exact reaction that causes the noise.
Water heaters exposed to hard water will create sediment inside the tank.
Following link shows sediment and remedies for gas and electric water heaters.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 25, 2011 | Reliance & 30 Gal LP Gas Water Heater
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Electric relay is smoking
You are correct. They are relays. A low voltage operates a higher voltage.
Jan 18, 2009 | Vanguard International Vanguard 82V66-2T...
Rinnai infinity hot water service, goes hot and cold...not fun in the shower!
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably machanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem,
Oct 20, 2008 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Water Heaters Logo
48 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
