My tumble dryer is sending out random smells similar to a blocked drain, even when not in use :(
MACHINE APPROX 5 MONTHS OLD- ALL FILTERS ETC BEEN CLEANED REGULARLY
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Get them out and let them sort it ug
Posted on Apr 20, 2015
Intermittant 0E error
I believe the OE error is generated if it takes too long for the washing machine to drain. If the drain is blocked or the pump is is not functioning well, the error will show up intermittently. I believe we experienced a similar error a couple of years back. After verifying the drain was clear, I replaced the drain motor, I believe the washing machine was about 5 years old at that time.
Feb 28, 2013 | LG WM-2277HW Front Load Washer
We have this samsung dryer and my towels smell like stale lockerroom smells and it is very bothersome. All of our other clothes smell fine, but the towels smell horrible.
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Jun 24, 2010 | Samsung DV218AEW Electric Dryer
My LG dryer is about a year old and suddenly smells musty and mildewy inside! The washer is just fine (that seems to be the majority of complaints) but the DRYER definately smells. I clean the lint tray...
yes I have the same problem and can't find help anywhere...it smells like mold but my husband says like a dead animal and it gets smellier by the day. I leave the door open on both the washer
Jan 02, 2010 | LG Dryers
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
The tumble dryer trips out
It sound as though it is overheating.
This may be caused by a reduction of air flowing through the machine.
Check all the filters and the out pipe for blockages that would restrict the air flow.
Dec 14, 2009 | Hotpoint Dryers
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Jul 19, 2009 | Dryers
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
White knight tumble dryer (condensing) - burning plastic smell and machine seems really hot
I have a whikpool condenser dryer that seems to work but has all the lights come on and a buzzing noise,any ideas to what it could be please? I have clearned all the filters etc
Apr 19, 2008 | Dryers
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
