Question about Zanussi Dishwashers
My dishwasher a zanussi DZT6252 THE ON/OFF LIGHT IS ON BUT I CANT SELECT A PROGRAM.
    Genius:
  • Zanussi Master
  • 1,585 Answers
Check door lock
Posted on Apr 20, 2015
4 Suggested Answers
SOURCE: Zanussi dishwasher DE6744 power indicator light
I had the same problem, in my dishwasher ZDI6895sx the solution to my problem was in the connection between the main PCB and the display/ control pcb on which the buttons/ led's etc are mounted.
On my machine there are about 8 wires in a ribbon type connector which connect the two pcb's, the connection to the main PCB is soldered and on the smaller PCB is a push on fitting, the connections on this pcb are prone to oxidation, there could also be stress on the connector from all of the button pushing, check the connecting wires for continuity with a multimeter if possible but otherwise just remove the connector from the samller pcb clean well(reflow with solder if required) and reseat the connector in its original configuration.
As always only perform this repair if you feel confident and have turned all power to the machine off prior to dismantling.
Let me know how you get on.
Kieran
Posted on Mar 29, 2008
SOURCE: I cant select any wash
Go through your manual to know how to select the wash programe
Posted on Jan 25, 2011
FaceTheFacts
  • 245 Answers
SOURCE: I have zanussi ZT 685 built in dish washer.when power on the green light comes on but does not allow me select any of the programmes. but does not allow me to select the program
You need a new control board most likely. This model might be tricky to find one on.
Posted on Jan 23, 2012
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Power is on, light is on,program stuck on 70'c setting. Toggle switch when pressed does not change program as it would normally.
i, just read yuor question, i have same problem with same model but atuck at 60. Did you resolve this?
Jul 06, 2011 | Zanussi 23 in. ZDi6053SX Built-in...
Some 1 gave my daughter a slimline zanussi dishwasher not sure what model it is but looks quite old. need a manual as the program numbers have faded and cant see them regards chris oh and its a aqua save...
If the model is correct then even without a manual the control set up is as follows.
From Lhs you will see on/off/ button next are the 2 lights top one is on/off and the bottom is for salt low light.The next button to the right is rinse and hold next Intensive 70 Degrees,next Normal 65,next Bio 50, next Quick wash 50 Degrees.To cancel a wash programme open the door and press the button for the prog. underway for more than 1 second until the corresponding light goes out.
The dishwasher is now reset and you can select a new programme.You can try this site for a manual.
www.appliancehelponline.com
Hope this helps.
May 27, 2010 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Zt685 built-in dishwasher. power light illlluminated but can not select program
door not closing properly can you hear door click? problem with door switch
Jun 25, 2008 | Zanussi Dishwashers
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
82 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
