Question about Toshiba Computers & Internet
On a Toshiba satellite l955-s5370n show a picture of the power conecttion for the color order where its connected?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 19 Answers
For all toshiba laptop help please call on the support at 347-897-1207 instant help provided and also basic settings will be configured
Posted on Feb 23, 2016
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: How to unlock a satellite l955-s5370n
call toshiba
Posted on Apr 09, 2015
Replace keyboard
There should be release screws on the underside, they might even be marked.
Sep 06, 2014 | Toshiba Satellite L955-S5370 Notebook...
Toshiba Satellite c655 is only showing blue screen after powering up.
Could you describe what it shows? Usually it shows something like STOP or similar words. A picture would be even better
Jan 05, 2013 | Toshiba Satellite L305-S5933 Notebook
LCD Screen colors are bad on toshiba Satellite M115-S3094
Was the screen showing all OK before you updated the driver? If so did you try backing out (uinstalling) the graphics driver? You mentioned gtaking screen cover off ... did you completely remove the screen from the laptop, including the wide connector at the top and the smaller one at the bottom, and the small one to the backlight? These connectors might be seated wrong, and you'll have to reseat them, mostly the big one at the top. Best o'luck, Moorethemerrier!
Sep 20, 2009 | Toshiba Satellite M115-S3094 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
PS2 Shows in black & white
Then is the cables, find other cables, some other same to the t.v conecttion hole to plug the cable, my t.v have some of does problems from s-video cable connection.Or try and look for settings menu color.
Dec 31, 2008 | Proscan 32LA30Q Television
Computers & Internet Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
