Question about Hoover Washing Machines
Hoover vhd 9163zd giving e05 error any ideas,where is it situated
    Top Expert:
  • Hoover Master
  • 10,875 Answers
    Genius:
  • Hoover Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 27, 2015
3 Suggested Answers
SOURCE: I have a Hoover vhd sensor Dry Washer Dryer and
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Posted on Oct 03, 2010
Jahn27
  • 1554 Answers
SOURCE: Hi - Have a Hoover
The problem is with the water temperature sensor located at the rear bottom of the tub just above the heater. Remove the rear panel to access the sensor then check the wire harness connection. Make sure the wires are connected properly. Replace the sensor if no issue is found with the connection which is part number 49015420.
Posted on Jul 12, 2011
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
I have a Hoover Vision HD 9 kg washing machine, type VHD 916Z. I does not spin when there are clothes in the machine, it just starts the spin then "gives up" after 0.5 to 1 second. When there are no...
Double check the waste pump on the inbound side, which could be the cause of a wrong feedback to the pressure sensor switch. The filter can be clean, but the collector from the basket to the pump can be obstructed.
Jan 26, 2015 | Hoover Washing Machines
I have a Hoover H160i that is coming up with E05 error. Any ideas?
Thank you. I ran a 2 and 3 wash (60 and 40 degree wash). It allowed me to put it onto a rinse/spin/cycle but it didn't allow the wash.
Nov 28, 2012 | Hoover H160I Front Load Washer
My Hoover VHD 1400 aaa has the front concrete weight off
This weight helps to balance the machine. needs to be put back on or replaced. Machine will not operate properly without it.
Mar 28, 2011 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
Hoover oph 714d optima 7kg washing machine fault code e05
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Aug 01, 2010 | Washing Machines
Washing Machines Logo
114 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
