Question about Jeep 2000 Cherokee Sport
My 2000 jeep cherokee sport is getting fuel and spark and won't start what can it be
    Master:
  • 467 Answers
If Fuel and Spark are Correct, it must be Air. Are any codes set? If so what are they. Check MAP Sensor 96 Jeep Cherokee MAP Sensor
Posted on Feb 03, 2017
StormStrikes
  • 104 Answers
SOURCE: 2000 jeep cherokee sport 4.0
I believe that year had distributorless ignition, instead it uses a form of coil on plug ignition system.
If you open the hood, stand at the front of the vehicle. Look to the left side of the engine, around the bottom of the valve cover (The valve cover is where the oil fill cap is. The oil fill cap is on top of the valve cover), at the bottom of the valve cover on the left side you will see a series of humps. Those series of humps is the coil packs, the coil packs are all in one long piece held down by three or four bolts.
Take out those bolts, gently pry up at the ends of the coil pack and it will eventually come out. You'll see on the bottom side the spark plug boots are attached to the coil pack. After you get the ignition coil pack off, you will see the spark plugs under where the coil pack came from, the boots on the coil pack sit directly on the spark plugs.
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: 2000 jeep cherokee sport fuse diagram
unfortinately the fuse box is under the hood and there is no panel inside the 2000 cherokee or diagram, i had to buy an online manual to find out what fuse went where for my jeep but its not with me. You can just pull the fuses out one at a time and look at them - I know its a pain. It might be your window controll switch - mine is bad as well. It is a common problem for these cherokees especially over 100k, they wear out - I initally thought it was my fuse as well because the lights in the window switch didn't light up anymore - but it is my switch.
Posted on Feb 15, 2009
  • 6982 Answers
Likely you are looking for a 30 amp circuit breaker...(Looks like a small rectangular metal fuse) But...if the power door locks work, i don't think that it's bad (serves locks & windows) My diagrams show a bunch of diodes and resistors inside the master (drivers) door switch, but I've had a few apart and never saw any. (embedded?) Personally I don't see anything that shows me reliability built into the switch...It's a really "iffy" design (one in my niece's Jeep only works when the sun shines on the drivers door) There is also a control module associated with the windows but I've never needed to replace one and the manuals never tell you where they are!
Check power at the switch and check harness where it goes through the rubber boot between the door and body. at least 80% of problems I've seen are either the switch or that wiring. Wires can be spliced and you can get a decent used switch at most scrap yards.
Good luck...glad they aren't stuck down!!!
Posted on Jun 27, 2009
  • 27 Answers
SOURCE: replacing the Antenna on a 2000 Jeep Cherokee
this is how we did it for my Dads jeep his was a 98 so it should apply. let me know if it doesnt and i'll go break it down on my friends jeep 2000
Unscrew the antenna and the base flat base nut. Unfasten the mud guard in the wheel well enough to pull it aside and reach up to the antennae. Remove the kick panel to find where the cable enters the jeep.
Posted on Nov 18, 2009
BCAS1298
  • 3092 Answers
SOURCE: 1998 jeep cherokee sport- i get a code p1682.
P1682 - Charging system voltage to low.
Posted on Nov 23, 2009
2000 Jeep Cherokee Sport will turn over but will not start
check fuel pressure and spark whats missing if door buzzer not workinh unplug crank sesor see if it starts working
no buss will be in the odeometer
Nov 03, 2013 | 2000 Jeep Cherokee
I have a 1998 Jeep cherokee sport. Was driving today and it died. Now there is no spark and no power to fuel pump. Changed fuel pump today and it won't run. Recently replaced oxygen sensors too
U need to check the crankshaft position sensor. The fuel pump will only have power for 2 seconds I till it sees a crank signal. It' controls the asd relay which turns on your spark and fuel
Apr 19, 2013 | 1998 Jeep Cherokee
2000 jeep cherokee sport cranks but no sparks all fuses good what could it be
crank shaft sensor just had this prob its located on top of trans
Jul 21, 2012 | 2000 Jeep Cherokee
1995 jeep grand cherokee cranks but won't start
I have a 1995 Jeep sport it crank but wont start I dont know what it could be
Jul 01, 2012 | 1995 Jeep Grand Cherokee
1995 Jeep Grand Cherokee Sport it just won't start. It cranks, that's it. It was running fine yesterday.
If it was running yesterday and only cranks this morning you need to determine which you are missing - spark or fuel. The spark is easy - pull a plug and let it spark to the frame. while cranking. If you have spark then you have to start checking the fuel system.
Jun 23, 2011 | 1995 Jeep Grand Cherokee
2000 cherokee sport 4.0 hard cold starts and rough idle
Did you try changing the air breather for the motor?You need three things inorder for the engine to run well. Air,fuel,and spark.since you had a tune up and fuel flushed.I can only think of two things.First I never heard of flushing a fuel filter,you change it ( not flush it ) change your fuel filter,eliminate the guess work.And change your breather.
Jul 25, 2009 | 2000 Jeep Cherokee
Long starting problem
did you try to check the spark plugs or the coil its seemd to me its a week firing some where try to make tune up then let me know whats happend thanx
Mar 18, 2009 | 2000 Jeep Grand Cherokee
Jeep 2000 Cherokee Sport Logo
134 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
