Question about Hoover Washing Machines
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
  • 352 Answers
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Posted on Apr 20, 2015
SOURCE: HOOVER NEXTRA HNL71663D WASHER DISPLAYING E05
I had exactly the same problem. After removing the back panel, I checked the two wires that go into the thermostat, they came away with no problem (not a good thing). Both of the wires were very brittle. I restripped them back and put two new connectors on, the problem was solved. Sounds obvious but make sure you turn the power off!
Posted on Feb 04, 2010
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
Daniel S
  • 4323 Answers
SOURCE: hoover oph 714d optima 7kg
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Posted on Aug 01, 2010
Jahn27
  • 1554 Answers
SOURCE: Hi - Have a Hoover
The problem is with the water temperature sensor located at the rear bottom of the tub just above the heater. Remove the rear panel to access the sensor then check the wire harness connection. Make sure the wires are connected properly. Replace the sensor if no issue is found with the connection which is part number 49015420.
Posted on Jul 12, 2011
SOURCE: i have a hoover wmh148df washing machine which keeps coming up with fault code E05 can anyone help me find out what this is
Hello there,
E05 is a temperature sensor fault.Now there are a few things to check before replacing the sensor. Remove the back panel on the washer. There is a heater on the bottom. On the side is a circular sensor with a couple wires attached to it.
First make sure all wires are connected.
Try tracing wires to board to make sure they are not cut or disconnected along the way.
If wires are good remove sensor and check for scaling on surface.
If scaling is present clean the sensor then put it back on and try a load. If problem persists you will need to replace the sensor.
Now sometimes the main board can cause this.
If all else fails replace the board.
Posted on Nov 01, 2012
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
I have a Hoover H160i that is coming up with E05 error. Any ideas?
Thank you. I ran a 2 and 3 wash (60 and 40 degree wash). It allowed me to put it onto a rinse/spin/cycle but it didn't allow the wash.
Nov 28, 2012 | Hoover H160I Front Load Washer
I have a hoover wmh148df washing machine which keeps coming up with fault code E05 can anyone help me find out what this is
Hello there,
Nov 01, 2012 | Hoover Washing Machines
I have HOOVER vhd 8143db80 when it went into its final spin, it started screaming. So I've taken the back off,I've noticed a lot of black carbon/metal dust on the pulley wheel. I've turned the...
That could be two things. Belts scream when they slip and are worn out. An bearings scream when they are dry or worn.
Your machine seems a bit obscure, as Google doesn't seem to know that model?
HOOVER vhd 8143db80 Google Search
VHD812
https://service.hoover.co.uk/manuals/VHD812.pdf
Feb 19, 2018 | Hoover Washing Machines
Hoover oph 714d optima 7kg washing machine fault code e05
Hi
Daniel
Aug 01, 2010 | Washing Machines
HOOVER NEXTRA HNL71663D WASHER DISPLAYING E05 CODE. CAN YOU TELL ME IF THIS IS A SERIOUS FAULT AND NEED TO GET ENGINEER OUT.
Aug 22, 2009 | Hoover Washing Machines
Washing Machines Logo
190 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
