Question about Ryobi Garden
How do I replace the petrol primer bubble - Ryobi Garden
    Habit-Forming:
  • 83 Answers
It usually is only 3 or 2 phillips head screws, although you may have to move the air cleaner on some models (pop the cover off). Use the correct replacement bulb for your machine.
Posted on May 03, 2015
  • Ryobi Master
  • 2,760 Answers
Simple !! just obtain a Ryobi fuel system repair kit (any Ryobi dealer ) , this includes a new primer button , unscrew two Phillips screws holding clamp ring down around bubble (save them) remove damaged bubble (all of it, sometimes leaves behind bits of it) install new bubble and verify it's down in groove , reinstall clamp ring and screws , fill fuel tank and prime button (pushing it )
Posted on Apr 24, 2015
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
Primer bubble
The primer bubble just pulls fuel from the carb and dumps it back to the tank, to replace it diss connect the two hoses, there are then two small plastic legs on the back, press them both in and the primer will just pop out.
Feb 26, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Hi there,i have a mcculloch tm210 petrol strimmer and the problem is that it will not start,i have noticed that the fuel primer bubble dose not come back out.please can you advise.
clogged fuel line or carberator. my weedeater did this at the first of the season. i took off both lines going to the gas tank and blew on each line separately while holding throttle open on carberator. i felt the clog go thru and put back together, poured a little gas in intake and it started right up and the primer worked right. good luck
Jul 03, 2010 | Garden
Will only run with choke on or barely open doesnt want to rev up have done carb kit fuel lines comp. check fresh gas, primer bowl wont stay full and gas in tank bubbles around a lot
Check the exhaust muffler, it might be blocked with carbon. Remove the muffler and start the engine, see if it runs. Soak the muffler in petrol overnight. Stephen.
Nov 09, 2009 | Garden
Is there a gasket under the primer bubble;it won't **** up gas
the pick up tube in the fuel tank is probably bad
Sep 16, 2009 | Garden
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
Garden Logo
255 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
