Machine is not letting water in - Washing Machines
  • 171 Answers
Try different temperature settings.
Check door switch and latch.
Make sure water valves are in open position.
Check hose screens and clean.
Posted on Apr 20, 2015
There comes black stuff out of the washer when i spin. Isit the stasoft?
Fill your machine with hot water (if you only have cold water connected, then add hot water with a bucket) until the machine is filled to the top mark. Add a cup of dishwasher powder and stir it to dissolve. You can also let you machine run a short while, but be carefull that the water is not pumped out. Turn the machine off and let it stand overnight. Then turn it on the next morning and let it wash a complete cycle. You don't have to let the rinse part of the cycle complete. Just turn the machine off when the first water has been pumped out.
What this does: The machine builds of a residue between the drum and outer housing which is not removed in the normal wash cycle, especially if you don't wash with hot water. LG recommends that the machine is cleaned in the above way once "fluff" or black residue is starting to show in clothes after washing.
Mar 11, 2015 | LG WFT1071TP Top Load Washer
Why will my machine not let in hot water?
Boy! That Machine sure told you Off! LOL...I hope you are OK and you did not get burn! Yes there is a separate (and Less expensive) Hot Water Inlet valve. BEFORE changing it Or any part on a washing machine be sure that A) Power is disconnected. and B) the water source is shut off. You may have to "bleed" out the Pressurized water by removing the filter or screen. Check your owners manual for the location.
Jul 26, 2014 | LG Washing Machines
No water inside washer
Does the water run right through the machine? There must be a way to let it stop inside and do what it is supposed to do. Have you tried to put it on the programme to empty all water? Then I think I would try to let is wash the shortest programme( no washing in the machine) At last let it spin You have before of course checked that all plugs are where they should be, that the water is on, the machine is closed. Kolbrun
Sep 19, 2013 | GE Washing Machines
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Mar 08, 2009 | FrancisFrancis! X1 Espresso Machine
Machine wont start
fill it with water start the machine when hot open side valve to let water out if it doesnt do the job remove water tank in the kit of the machine there a little pump put water in the pump in the water hole force water in there with side valve open let me no pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
