Question about Cameras
I opened my power shot, it was dirty, I cleaned it, I want to fix it back, Please instruct me or give diagrams, thanks
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Not much t go on, but perhaps your model is already done on this site?
Canon PowerShot Repair
Posted on Apr 23, 2015
Treadmill is running at maximum speed
please RUN the software calibration for easy diagnostic and fix i. However you must test the speed sensor,clean for dirty, or open/faulty see, tight the connector and clean it. the diagram attached.
Read you owner manual or download from javascript:;www.fitness.manualsonline.com
God bless you
Dec 02, 2013 | Nordic Track Exercise & Fitness
2008 gmc 2500hd crew power locks not working on driver side front and rear. Passenger side fine
please see the diagram attached, test the switch, for open or dirty, use de the wd-40 , look for some wires loose or connector, clean it, and of course see for the fuse open or corroded or oxide clean contacts, or test the motor for faulty.
see the diagram attached.
God bless you
Nov 20, 2013 | Cars & Trucks
Error code 02
normally is a faulty PCA, RAM memory, or eeprom faulty. Reset the machine, and if the problem persist adjust the REED switch, see the diagram, clean it, test for open or faulty, clean the connector and tight very well.
Open the display board, and clean the ribbon cable with pencil eraser the contacts from dirty and corrosion. You can use the contacts cleaner for the rest of connector, clean it very well from dirty, corrosion. and try it. see the diagram attached.
God bless you75cd6ef2-2cc7-4b73-bb3e-036688210718.gifa9fbc824-f724-486a-8795-fa598ed28e28.gif
Jul 10, 2013 | Exercise & Fitness
My old front load whirlpool isn't draining. Someone suggested opening a plug on the bottom left of the machine front that may have gotten clogged but we were unable to open it. any suggestions?
hello,
the solution giving to you i also a way of draining the water from the washer ,
But i will like to draw back your attention back to the drain pipe inside the drum of the washer..... what you need to do to fix up (solve)the problem of the drainage from here is that you have to bale out the waste water in the drum of the washer to see the cloth or dirty that have form up to block the pipe of the water out flow, remove any form of dirty around the pipe that have stop the water flowing as is expected to, with this the problem of blockage is solve.
please note this important information PUT OFF ALL FORMS OF POWER SUPPLY CONNECTED TO THE WASHER.
Thank you and thanks for using fixya.
Jun 15, 2010 | Washing Machines
Camera was on, working fine. When powering off, telescoping lens did not retract so lens remained extended just a bit with lens cover open. Waited a few minutes, turned it back on and I get the "access"...
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 20, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Same problem with my Cannon Power Shot and it's only a month old.
I do not want you to break this anymore then its already so I would refer you to a camera shop to have it cleaned out. But in genral you need a can of compresed treated air open up the camera and give it a couple shots of air in the lens assy this would clean it out and unstick the lens.
Sep 23, 2009 | Canon IXUS V2 Digital Camera
My bissell ready dry doesn't clean my carpet.
my bissel ready dry is not sucking the water up
Mar 30, 2009 | Vacuums
The PIXMA MP 110 won't print.
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
