Question about Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER
How to replace censor that means encoder strip in mp 287 printer?
My mp 287 encoder strip open from spring. how to fix it or replace it?
3 Suggested Answers
  • 103 Answers
SOURCE: what is the solusation of when the canon mp287 eror code 5b00
It means the "Ink Absorber" is Full / Almost full. There an excellent Step by step/ How To fix video on Youtube for this model of printer:
https://www.youtube.com/watch?v=-6DmGIVtWLE
Enjoy !
Posted on Jan 10, 2015
  • 79 Answers
SOURCE: Hey guys! My printer Canon Pixma MP 287 Blue color isn't printing. But all color are well printing. Please tell me remove the problem
Do you have single cartridges for each color? You may just be out of blue. Try you Tube or canon Tech Support.
Posted on Mar 18, 2015
Canon Multipass F60 error
Encoder strip is the transparent strip which behind the cartridges carrier2b85ffb.jpg
A: Encoder strip (semi-transparent gray strip)
B: Carrier belt (black and brown toothed belt)
Please open the cover and check if the carriers is coming to the center ,if not gently pull the cart carrier to the center and then power on the printer , be carefully with encoder if its damaged then you cannot use the printer...
Good luck...
Oct 13, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Carrier stall.
Solution:
Nov 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Clear carrier jam
In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
Solution:
1. Cleaning the encoder strip:
2. Repositioning the Encoder strip.
Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jamed
Solution:
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Encoder strip have hole. How can i take it out?
Why would you want to remove the encoder strip? The strip can be carefully cleaned in place by following the instructions here.
If you really want to remove the strip (not recommended) open the lid (with the power on). Wait for the printer noises to stop, then carefully move the carriage (with the print cartridges in it) to the left. Unplug the printer power.
The encoder is held on a metal tang at the right side and a spring on the left side. Carefully grasp the encoder near the right side and pull it to the right so it can be dislodged from the tang on the right. You will need to bend the encoder slightly to unhook the end. Once it has been loosened form the right you can then release the left tang and carefully remove the encoder.
When reinstalling the encoder reverse these steps. First thread it properly through the sensor on the back of the carriage, then connect the left end to the spring, then connect the right side.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jun 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Loose Parts??
Sounds like the Encoder Strip, but without the Brand Printer and model number, I cant be 100% sure.
If it is the encoder strip, this is what the printer uses to tell where the carrriage is located at. Without it, the printer won't work.
You can try to repair but it will take a little time. 1st make sure that the encoder strip isn't torn at either ends where the spring goes in.
The encoder strip goes from 1 end to the other end, and it also goes through a small opening in the back of the carriage unit.
If you have a make and model, I could be a little more specific.
Good luck.
Feb 05, 2008 | Office Equipment & Supplies
Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Mar 31, 2007 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER Logo
141 people viewed this question
old marine
old marine
