Question about Samsung AS18A6RB Air Conditioner
Air conditioner is working only for a short time ie around 2 hours after that the stabilizer shuts down
    Problem Solver:
  • 11 Answers
Check and need to change the capacitor
Posted on Apr 20, 2015
Unit comes on runs for a minute or two then shuts off will not come back on for a while
Its tripping, usually stabilizer has a timer thats why it comes on back again after 2 mins. Probable cause, compressor short circuited, stabilizer facing high voltage supply or some component like cooling fan or blower motor jammed and causing it to trip
Apr 07, 2014 | Heating & Cooling
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
My coleman mach air conditioner will blow cold air for around 4-5 hours then air is no longer cold? I could turn it off for a few hours and it will blow cold air again? what could be my problem?
sounds like the compressor is going in to overload this is a protection if it gets to hot make sure your condenser fan motor is working properly and that your condenser coil is clean I would rinse it out anyway to make sure. when you shut it down you are allowing the compressor time to cool down and it restarts but you have a high pressure head problem .
Jul 31, 2011 | Heating & Cooling
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Voltage Stabilizer for LG 1.5 ton window type ac
You should have around 120-125 volts at the outlet. If you have less than 110 volts at that one outlet, you may need to have your house wiring checked. Go ahead and call your local power company and have the power coming into your house checked at their transformer. They should do this at no charge to you.
Aug 02, 2009 | Heating & Cooling
Amcor ALD12000E portable air conditioner shuts down every hour
Is it leaking or shutting off on the overfill?
If it is leaking you have a stopped up drain inside the unit.
jim
Jul 27, 2009 | Amcor ALD12000E Portable Air Conditioner
Problems with Amana Quiet Zone 12M12TA, kicks off after short runtime, but other times runs for an hour cooling OK. Hear a clicking when it shuts down? Could not find a fuse ot relay?
Does it run longer when it's cooler outside like at night? If it is, it could be shutting down on high pressure or temperature caused by dirty condenser or you could have an overload in the compressor wire box that is weak or has a loose connection. Check the condensor coil to see if its dirty and see if it has an overload on the compressor.
Jul 11, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Shutting off
I would try the same solution as the E1 error code, Not sure if it will work, but it seems to be the same issue
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Sep 10, 2008 | Sharp AF-S120FX Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
78 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
