Question about Alesis Dm5 Drum Module 18 Bit
My dm5 won't save my settings. I click the store button but if I turn it off and back on again it automatically says "reinitializing" and then my settings are gone. How do I fix this?
    Habit-Forming:
  • 61 Answers
Internal battery for memory is bad. Replace.
Posted on Jun 02, 2015
2 Suggested Answers
  • 5603 Answers
SOURCE: i can't get my dm5 drum set to play
DO the initialize again as on this site:
http://www.hartdynamics.com/support/alesis.html
and follow the directions about setting each pad volume and the dynamic =1
Posted on Feb 06, 2010
Anybody ever figure out the Alesis DM10 module blank screen with some led lights on?
Try a reset before going to assistance:
There are two ways to reset the DM10:
To fully restore the module to original factory settings, hold the EXIT and STORE buttons while powering on the module.
To reset only the kits, sequences, or trigger settings:
  1. Press UTILITY to enter the main Utility Menu.
  2. Press SYS (F4) to access the Accompaniment Settings.
  3. Press INIT (F2) to access the reinitialization page.
  4. Use CURSOR UP/DOWN to move through the following menu items:
    • All Kits: All of the module's kits and their settings will return to factory default
    • All Sequences: All of the module's sequences and their settings will return to factory default
    • All Trigger Settings: All of the module's trigger settings will return to factory default
  5. Highlight the option you would like to reset, then press EXEC (F4).
  6. A window will appear asking you to confirm your choice. To confirm and reinitialize the selected settings, press YES (F1). To Cancel, press CANCEL (F2 or F2).
Aug 20, 2015 | Alesis Music
Wanted the instructions to assemble a set of ElectricDrums,/DM5,ALESIS
Which is it... a DM5 set or an SR16? This Fixya thing is disgusting trying to offer up brands and models.
IF you might have an SR16 that has a problem, the USUAL problem is using the WRONG power supply with it. You CANNOT use universal power supply... you must use the official adapter or it will not work.
Nov 01, 2011 | Alesis Sr 16 Stereo Drum Machine
I have a DM5 18 bit drum module. It is a while since it was last used and I can't find the mains adapter. I bought a new one and have it set at 9V. The unit switches on but it is very dim and I...
You CANNOT use one of those universal adapters, period. The DM5 Alesis takes an AC output adapter. You need 9 VAC at 830ma or more. AC output adapters are hard to find and you are not the first to try a universal and find that they don't work! Here is one of MANY sources on Ebay:
http://www.ebay.com/itm/NEW-9V-1A-AC-AC-POWER-SUPPLY-ADAPTER-fr-Alesis-DM5-Drum-/110700117691?pt=COMP_EN_Networking_Components&hash=item19c63dbebb
Sep 20, 2011 | Alesis Dm5 Drum Module 18 Bit
I have purchased a replacement power cable for my dm5 pro and it doesn't seem to work. it is a uk ac 9v 1000Ma adapter. what is the problem? how do i solve it? thanks, lee
Make SURE the adapter is NOT a DC output adapter. You need 9VAC output at about 1000ma. (1 amp) Many people try to use "universal" dc adapters and they will NOT work with the DM5.
Aug 23, 2011 | Alesis DM5 Pro Drum pad (DPDM5P)
Where does hihat control cord go
The hi-hat trigger goes into trigger #1. Using a footswitch will change the hi-hat trigger sound to a closed hi-hat. On page 8 of the user manual is the list of triggers and their assignments. Note that some new triggers from newer drumsets use TRS cables because they have two sensors within the drum head... Often the new ones have a rim shot snare trigger as well as a trigger for the mesh head. These newer different brand triggers would require special cables to be made to attempt to use them with the DM5. The DM5 is older technology now but is still useful.
Jul 25, 2011 | Alesis Dm5 Drum Module 18 Bit
MY ALESIS DM5 WAS PLUGGED TO 220V AND AFTER A WHILE STOP WORKING ( IT IS FOR 110 V ) IS ANY FUSE I CAN REPLACE?
Hi pcruzx,
Sometimes replacing the fuse alone with exact voltage and ampere ratings will cure the problem(you're lucky) but not all. Sometimes further damaged gone to other parts most especially the voltage regulator transistor/IC (mounted in heat sink) and the opened the fusible resistor in line with the supply(B+).
First check the fuse, for sure it was already blown. If you've replaced the fuse and immediately blew again after powering on the unit, this was an indication of shorted parts near the AC line. Click this LINK for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 01, 2011 | Alesis Dm5 Drum Module 18 Bit
My Dm5 drumkit module keeps intermittently ''freezing''. After powering down and switching back on it's ok again for a while, then after a varying amount of time does the same thing again, i am using it...
Intermittents are hard to find the cause of... but let's give it a shot...
Things to try or verify:
1, Verify power connector is fully seated and supply is correct one and is producing the desired voltage..
2. Verify that the amp this connects to is powered by the same wall receptacle. (this is a ground loop noise issue) Also don't let mic's or other electrical equipment touch the drum pad mounting system.
3. Verify you are not inadvertently generating static discharges. If you find yourself drawing sparks when you touch things this is an indication of static. if this is a problem, raise humidity to 40%.
4. If unit is subject to heat, try cooling with a fan to see if it helps the situation.
5. Verify the unit is NOT being vibrated.
6. IF THE UNIT is quite old, verify an internal backup battery is not depleted... they usually are about 3 volts when OK.
Jun 26, 2010 | Alesis Dm5 Module with Tk5 Acoustic...
I can't get my dm5 drum set to play,I have reinitialized the sound module and it does not make a sound.
Feb 05, 2010 | Alesis Sr 16 Stereo Drum Machine
I have a Fender Cyber Twin that does not save my settings. I can set up my volume,gain, treble ect.. hit save button to store the setting and if I switch settings to a different sound and back to the...
From the manual... is THIS the proceedure you are using to save the settings?
 T o SAVE:
1) Press the SAVE key once and a prompt displays the PLAYER’S
LOUNGE preset about to be replaced, (example prompt shown).
2) Rotate the DATA WHEEL to select a PLAYER’S LOUNGE preset to
overwrite with the currently active amp design
(last chance to press EXIT, cancelling the save).
3) Press the SAVE key a second time to complete the save.
Jan 24, 2010 | Music
Alesis Dm5 Drum Module 18 Bit Logo
260 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
