Question about Sewing Machines
It is stuck in reverse
I have oiled it and cleaned it
  • Sewing Machines Master
  • 1,860 Answers
It's possible that the reverse could be damaged or broken, having it checked would be a good idea
Posted on Jun 03, 2015
Sears kenmore 158.18023 sewing machine is stuck in reverse!!
How long since the machine has had a thorough clean and oil? Could be seizing due to old oil that has dried.
Wheel on right side that controls the needle up and down is very tight...
Dec 19, 2017 | Kenmore Sewing Machines
The reverse button is stuck on reverse. How do I fix it to go forward?
Hello Leah, I think you need your machine cleaned and oiled. Over time, the old oil will dry out and even get sticky. This can cause the feed dogs to stay in the reverse position.
Oct 10, 2015 | Janome Sewing Machines
My machine has not been used since 2004 and is stuck in reverse How do I fix this?
If it is a mechanical (NOT computerized) sewing machine, it most likely needs a good cleaning and oiling after not being used since 2004. Mechanical sewing machines need to be cleaned & oiled every time a bobbin is changed, every 8 hours of constant sewing, or every six months when not in regular use. Use only good quality sewing machine oil (NOT stale old oil, 3-in-1, WD-40, or cooking oil) and oil only 1 or 2 drops each spot as directed in the owner's manual.
Sewing machine oil tends to degrade over time and will eventually glue moving parts together. Keeping it maintained is a simple way of insuring it will work the next time it is used.
Sep 12, 2015 | Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
How do I fix my Viking sewing machine model6010 it only runs in reverse
Probably a stuck slide block which is common on these machines.
Usually not a difficult repair but the back cover needs to be removed and the mechanism oiled.
Apr 23, 2015 | Sewing Machines
Fabric only feeds in reverse
It sounds like the reverse button might be stuck. Try unplugging the machine and carefully work the reverse button or lever up and down. Bobbin could be in wrong. Also, how long since you cleaned out the bobbin holder. Try using a pipe cleaner. You might be amazed at how much comes out. There's a Missouri Star youtube on cleaning. You may have done this. I'm just trying to think of what it could be, not insult your intelligence. Hope this helps.
Feb 05, 2015 | Janome Jem Silver 662 Mechanical Sewing...
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
Husqvarna Viking Sweden Model 6030
On all sewing machines there is a button or lever which makes the machine go backward. The button could be stuck, if so put a drop of oil on it and try to release it. If there is a lever that has been raised which puts the machine in reverse, simply lower it to the lowest position. This should solve the problem.
Zelma
Nov 29, 2007 | Husqvarna Viking 1
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
