Question about Fuji FinePix F401 Digital Camera
Battery charging The battery will no longer charge (no blue lights on front) either in cradle or direct with cable BUT I have tried my Dad's battery - exactly same camera and that won't charge in my camera either but will in his. This therefore looks like it's the camera and not the battery?! Any advice appreciated Gary
  • Gary C Nov 14, 2007
    I tried my dads charger and no difference. How do I clean the input plug apart from blowing into it? - done that and no differecne?
  • Gary C Nov 15, 2007
    Any advice please - got a family party this weekend where I need the camera!
    Sergeant:
    Champion:
  • 306 Answers
Its the camera, the charging isolators are malfunctioning, needs repaired or replaced
Posted on Nov 15, 2007
  • 749 Answers
Before we assume that it could be the camera! ever tried using other chargers? check the specifications (output voltage and current) of your charger! try comparing it to your Dad's charger! if they match, it would be safe for you to use it on yours! try cleaning also your camera's charger input plug!
Posted on Nov 14, 2007
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
I want to use my old BCE250. when I put the headset to get charged, it blinks once and not any more. I put it there for 10 hours but after that when I push the button there is no blinking. Is its battery...
Hello due, your battery is dead or the battery circuit has an issue -just as mine-.
You can of course get rid of this problem by yourself if you have some skills...
Check this out:
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
If it is the circuit, then continue reading...
"The circuit on the internal battery has an issue and I cannot measure the voltage through it correctly. The battery reads 3,55 V, while the circuit reads 0,55 V. So, I have the same problem as above then... A blue flash and nothing else, no charge... I am going to remove the circuit of the battery and connect it directly to the charger pins. I believe this will not cause any issues. At least, I will be able to charge the headset this way. I will post once more should this method fails." This is my solution. And it worked. The headset in the cradle is looking at me with blue light on -charging!- Don't forget to take it out of the cradle after 2 hours as there is nothing there to protect the battery any longer.
Jan 06, 2010 | Jabra BT250 Consumer Headset
My harmony 880 will not charge
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show2_bing.gif should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
Dec 02, 2009 | Logitech Harmony 880 LCD Remote Control
Can't get the docking station to charge the remote battery. blue light. Not sure if I am getting good contact. Have used contract cleaning solution with not success. Appears that I do have poewer coming to...
Generally there are three possibilities (apart from the battery going bad) that can cause your battery not to charge:
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. This sounds like it could be your problem. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT (sounds like you tried this). Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you decide to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together.
Oct 26, 2009 | Logitech Harmony 880 LCD Remote Control
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Does not hold a charge. I have tried charging it for 2 days and when I unplug it and check the battery it says zero charge and shuts off!
if you see the amber light on the charging cradle then your battery no longer holds a charge. if you don't see the amber light then your pda is not charging when in the cradle. most likely it's a battery problem. good luck.
Jul 16, 2009 | HP iPAQ RZ1710 Pocket PC
The PC is not switching on
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Feb 02, 2009 | HP iPAQ RX3715 Pocket PC
Dead!
Best regards,
Apr 22, 2008 | HP iPAQ RX3715 Pocket PC
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Fuji FinePix F401 Digital Camera Logo
103 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
