Question about Refrigerators
My KIC Supercoolfridge 223l is overfreezing even with the setting on 1 resulting in the freezerdoors not closing
  • Refrigerators Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Posted on Apr 21, 2015
  • Raymond Cupido Apr 21, 2015
    Thanks Jjonny Rendon much appreciated
  • Jorge Rendon
    Jorge Rendon Apr 22, 2015
    your welcome
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: KIC 223l fridge - what length time reqd to let gas settle?
if it was transported upright you should be able to plug it up right away and allow it to start cooling peyton..
Posted on Jan 28, 2009
heatman101
  • 43501 Answers
SOURCE: My kic fridge is not
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.
Lock throttle trigger on,
Start on full choke till it fires,
Switch to half choke and it should fire up on high revs,
Blip the throttle and it should turn to tick over.
If it still keeps cutting out it could point to a carb or fuel takn issue.
Aug 04, 2012 | Husqvarna 223L
I have a KIC 223l. I moved into my residence yesterday and its not cooling. The moving took 5 min while it was lying down. I immediately switched it on when i got into my room. Its been on for less th
Hiya, u should leave a fridge and freezer after moving it at least 24 hours before switching it on because the gases need to settle. If it has been switched off perhaps you need to check the plug just in case the wires have loosened. hope i was of some help to you kind regards
Feb 11, 2012 | Refrigerators
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
My kic fridge is not freezing whereas my freezer is overfreezing. Can you tell me what is wrong with it.How can I get it fixed.
heatman101
Sep 06, 2010 | Refrigerators
My KIC KTF255P-Aa Fridge is heating up
It's in defrost cycle, But it's getting to hot. has a limit on it think it's not working.
Sep 22, 2009 | Refrigerators
Jan 28, 2009 | Refrigerators
Fridge KIC 223L- FRIDGE NOT COLD ENOUGH
Gas; which also means that it has a leak that must be repaired and fixed. You cannot  buy refrigiation gas unless you have a license from the EPA.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Overfreezing
The damper will close when door is opened and will open when the door is closed and the refrigerator needs to cool off
Jun 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
