Question about Sewing Machines
My thread is not cutting when I push the scissor button on front of machine. I have an Elegante 2 Nancy Zeiman special edition
  • Sewing Machines Master
  • 1,860 Answers
The scissor button may need to be checked for a damaged or broken part
Posted on Jun 03, 2015
4 Suggested Answers
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
sewinsnap
  • 135 Answers
SOURCE: when i touch the scissors icon to tie off the
Have you taken out the bottom bobbin parts and cleaned out the lint from there? That is probably all you need to do.
Posted on Jun 24, 2010
SOURCE: My baylock esante ESi-2 is not cutting the thread..
sounds like the machine needs to be checked at a sewing machine shop
to find out what wrong with it
Posted on Apr 28, 2012
Scissor button stick hand wheel won't turn
Sewing Machine Measuring Tape Scissors Iron Button ...
www.amazon.com/Sewing-Machine...Scissors.../B00K...
28 Sewing Hacks That Will Change Your Life
www.seamsandscissors.com/28-sewing-hacks-that-will-change-your-life/
Nov 1, 2014 - We here at Seams and Scissors have compiled 28 Sewing Hacks That Will Change ... Use a hair straightener to press fabric between buttons or embellishments. 17. ... Have a spool that is too big for your sewing machine? ..... My hint: I like to sew with the serger cones, so I just stick a drinking straw over the ...
Amazon.com, Inc.
Rating: 5 - ‎2 reviews
Quantity: 1 bead at listing price. Bracelet is not included. Last image shown as example; Compatible with all major brands charm bracelets, such as Pandora, ...
Search Results
    the handwheel on my sewing machine is stuck solid and won't turn ...
    https://answers.yahoo.com/question/index?qid...
    Feb 27, 2009 - Update: hi all, thanks for all your advice but it is the actual handwheelthat has seized up completly, i have no needle, thread or fabric in the ... Turned sewing machine hand wheel backwards, now it will not sew ...
    Nov 2, 2011
    Sewing machine: needle won't move up or down, even with ...
    Feb 23, 2010
    Sewing machine needle won't move up or down?
    Feb 1, 2009
    Sewing machine wheel jammed!?
    Sep 21, 2008
    More results from answers.yahoo.com
    Help me diagnose and fix a problem with my sewing machine - Sewing ...
    artisanssquare.com > ... > Sewing Machines
    Jul 31, 2012 - 14 posts - ‎6 authors
    The foot pedal doesn't make the needle go up and down, either. I unthreaded the ... I'm traipsing in the dark here, I'm assuming the power turns on ? ... There could be a bunch of thread inside the balancing/hand wheel.I found ...
Jan 25, 2016 | Sewing Machines
Needle thread cuts too short
Consult the owner's manual. Supposedly there should be a way of changing that thread length setting.
Jan 21, 2016 | Janome 11000 Memory Craft Special Edition...
What is wrong with machine I have tried all the instructions and it makes a horible button hole
most sewing shops/fabric shops that sell or service machines have people who are willing to show you how to do it regardless of the make of your machine
there is a knack to the job that is difficult to print in instructions
Sep 02, 2015 | Sewing Machines
Please help I have a singer 140 imperial anniversary edition model 7050 sewing machine, I cannot figure out how to wind the bobbin desperate!! Thank you!
Well, the good news is you can download your user's manual free if you go to the Singer Sewing Machine site. Just select Support, and there is an Instruction Manual option. Enter the model number, 7050, and it is pictured and explained there, beginning on page 15.
You have a Touch 'n Sew slant needle machine, which means you can buy additional feet, as long as they are slant needle ones, and they're very widely available.
Another good feature is those machine wind the bobbin right in place. I have had several of these machines for many years, and frankly, it's my favorite, most trouble-free method.
Bobbins are also widely available; however, your bobbin is available with or without a center button. Yours HAS the center button.
Feb 19, 2015 | Singer Sewing Machines
How do I thread the nedle
the easiest way for me to thread a needle is: 1. check to see which direction the needle eye is facing... some machines had the eye so you threaded it from the side... nowadays it is usually from the front... the opening facing you when you sit in front of it. 2. wet the end of the thread-about a half inch or so.. then take very sharp scissors and cut the very end of the thread off, but leaving some of the wet tip there... the moisture keeps the thread from unraveling as it goes through the needle eye. 3. now carefully slide the thread end through the eye. 4. Once it is through, pull at least 8 inches of the thread through (so it doesn't pull back through the needle when it first starts sewing the fabric)
Dec 28, 2014 | Sewing Machines
Machine stops while sewing elegante 2
Check to make sure there is plenty of thread on the bobbin.
Mar 18, 2014 | Baby Lock Ellure
Apr 27, 2012 | Baby Lock Esante
I replaced the thread in my bobbin the same way i always do but i guess i did something wrong or by replacing it just made my problem stand out but now every time i go to sew, the top string gets cut on a...
That is your thread cutter. Depending on what machine you have, whether it is automatic thread cutter on an arm or just a manual one. If it is automatic, pop the cover off on the left top of machine next to the bobbin area. The arm should be seen there. It moves like an elbow. Push your thread cutter (scissor button) and watch how it works to see if it has come off the post. If you don't have automatic thread cutter, perhaps the thread cutter is not pushed all the way back in its place. The thread cutter looks like a triangular piece of flat razor. It could be sticking out too far or perhaps bent. I have fixed mine before, but be careful.
Feb 05, 2011 | Husqvarna Sewing Machines
Needle up down moves the embroider
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached.
It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving.
If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Jan 05, 2010 | Husqvarna Designer I
On a babylock elegante the bobbin thread shows,
Jul 05, 2009 | Baby Lock Ellure
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
