Question about Pyle 6.5in ceiling w/70 volt spkr trans pair pdic60t
How to wire these speakers in series or parellel cirecuit?
Using 70V amplifier with common and 70V out to speakers
    Top Expert:
  • Pyle Master
  • 51,307 Answers
Wire speakers in parallel as the power diminishes after each speaker and before the next one if wired in series
Posted on Apr 20, 2015
What is best way to wire speakers to 70V amplifier
If you are attempting to connect standard 4 ohm or 8 ohm speakers to a 70v amplifier, you will need to purchase "MATCHING TRANSFORMERS" for the speakers. These matching transformers will be available from the manufacturer of the 70v amplifier.
Apr 20, 2015 | Pyle 6.5" Dual In-Ceiling Speaker System
How come my two subs wont get powered with a 12 ohm load. is it to high of a load. they are 12
HelloCheck the output impedence [indicated in OHms]]. You can get it from its manual. If it is designated as; 8OHms for example; you can connect one 8OHMs speaker direltly, or two 4 OHMs speakers in serieal connection. Likeways, if the output impedence is 6OHms, you can connect one 6OHms speaker direltely, or 2 12OHMs speakers in parellel. Just see, when we connect thow speakers in serieal, the impedence will be the sum of both speaker impedences. if we connect the same in parellel, the impedence will get halved. OK.
Dec 19, 2011 | Car Audio & Video
How to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
How do i hook up kicker solo baric in the box
Option 1 (parallel/parallel) = 0.5 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I hope you can help:-) I have a Realistic 35 watt solid state P.A. amplifier and on the back of the amp is this: 70V 16 8 4 COM There are holes under them for wires, how do I hook up the speakers to this...
This would depend on if you are using 4,8,16 ohm speakers or a 70v system.
For regular speakers the (-) wire would go to the COM terminal
the (+) would go to either the 4,8 or 16 ohm terminal (Check on the speaker itself for the "impedance").
If more then one speaker is used then there is some other math involved, but i can help with that.
The 70V terminal is used when powering a bunch of celing speakers like in stores and malls. Each speaker has its own transformer on it, all the transformers are connected togeather in a chain and wired to the COM and 70V terminals.
Nov 13, 2009 | Audio Players & Recorders
How do i connect multiple ampliers to one source and equalizer?
why do u want to use 3 amplifiers connected in series ?or even parellel.?remember in series amplifiers 1+1+1 does not make 3.it may make 10,hence the speakers may go bust .
Aug 24, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
What Crest Amplifier series replaces the VS series
This is kind of an ambiuous question. Are you looking for barrier strip inputs and outputs? Are you looking for 70V output lines? Or are you looking for a standard 1/4" TRS input with either 1/4" or speakon outputs? If you can describe your application requirements, I can provide you with a recommendation.
Thanks,
Dan
Mar 09, 2009 | Crest Audio CPX-900 Amplifier
Open Questions:
See all Pyle 6.5in ceiling w/70 volt spkr trans pair Questions
Pyle 6.5in ceiling w/70 volt spkr trans pair pdic60t Logo
98 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
