Question about Dirt Devil Feather Light Bagged Upright Vac M085590
Sucked something up and it smells like its burning,nothing in the roller
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 169 Answers
You have to remove the bottom cover on vac something is jam inside causing the motor or belt to smell
Posted on Apr 20, 2015
Burning smell and noise from vacuum
The roller head may be turning, but something could be rubbing and causing the belt to slip slightly. I'd remove the belt and beater bar and look for foreign material that is stuck
Jan 07, 2015 | Sebo ET-1 Powerhead White
I can smell burning coming from vacuum
If it smells like burning rubber, most likely the belt is burning from friction. Either there is something stuck in the brush roller or the brush roller needs replacing.
Oct 02, 2014 | Vacuums
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Roller not spinning
Possible belt broken. If you smell an odor like burning rubber it could be the belt that turns the roller if not the belt could be broken already.Possible string or something else wrapped around roller. If you have animals in home they shed and the hair or fur gets wrapped around roller and it will stop the roller.
Mar 06, 2012 | Vacuums
Vacuum making high pitched noise and smells like motor is burning
try repair first for quote and if too expensive then replace. 5 years is about the average life span.
Jul 01, 2009 | Dyson DC14 All floors Bagless Upright...
Burning smell when i vacuum.
Is there a lever on the side that switches the unit between hard floors and carpet i.e. a switch that can turn the roller off? If so, check that the belt is sitting properly in that mechanism, and not rubbing on the side.
Other there may be a fault with the motor. Sounds like not an easy fix so may be worth the trip to see a Service Technician.
Apr 08, 2009 | Panasonic MC-V5005 Bagged Upright Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell when vacuuming, not belt
Try turning the vacuum on and hold the base up so you can see if the roller is turning. Odds are it is not and what you smell is the belt burning (not literally). If the roller is not turning, look for anything that is binding it - after you have unplugged the power cord. Probably the roller head is not fully aligned with the retention lugs that hold it in place or the belt is not properly placed on the roller itself, or if it is a used model, hair and twine can get tangled in the roller and cause it to stop turning.
Dec 26, 2008 | Bissell 5770 Healthy Home Bagless Upright...
Roller brush on x5 chipping apart
Not too good, but there are motor problems with these models all the time. Personally I do not know it can be fixed without replacing 3/4 of the machine, which can be pricier than a new higher quality sweeper. I work for a repair shop/ dealer so if you need some assistance let me know.(570)326-1731
Feb 22, 2008 | VAX Appliances Vax X5 Bagless Upright...
Dirt Devil Feather Light Bagged Upright Vac M085590 Logo
67 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
